How to press in or remove RC10 Stealth roll-pin
- ZED32
- Has thanked: 166 times
- Been thanked: 242 times
I'm sure this has been discussed numerous times before, but this is the answer I wish I found on Google when doing my sleath. Find a vice or pair of pliers or channel locks or vice grips. Cut a slit into one end, then position the roll pin like I have here. You should be able to press the pin in no problem. Same for pressing it out. Get it flush on one end, then grab it with pliers and rock it back and forth until it comes out of its little hole. Hopefully someone finds this helpful one day.
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
Re: How to press in or remove RC10 Stealth roll-pin
That's a good technique. It gets used for the rear axles too
https://www.rc10talk.com/viewtopic.php?p=573786
- 1543 Views
Last post by Lonestar
- 1029 Views
Last post by SteveK
- 2408 Views
Last post by R6cowboy
- 876 Views
Last post by wyldbill
- 553 Views
Last post by longboardnj
- 1778 Views
Last post by Trackingz
- 664 Views
Last post by filzemail
- 821 Views
Last post by knucklebuster
