A $3 roll pin punch
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Re: A $3 roll pin punch
Every hardware store I've been to this weekend has them. I start the pins with a larger nail countersinking punch (the cheap ones from Lowe's), then switch to the 1/16" roll pin punch when it's down to the surface.
http://www.lowes.com/pd_142008-1431-592-0_0_?productId=1016481&Ntt=punch&Ntk=i_products&pl=1¤tURL=/pl__0__s?newSearch=true$Ntt=punch$y=0$x=0
I V-block made from hardwood from the hobby shop will probably work better than an open vise, like in the manual, but that's been working OK so far.
I have scratched so many shafts and axles using pliers to get these things out. Since I was replacing the topshaft with an RPM kit anyway, I just ground the ends off of one of the used Stealth's I bought last summer. The remaining portion of the pin came out in 5 seconds today.
Now I can replace all those pins I have squeezed so much that they just slip in without any friction.
- 2424 Views
Last post by R6cowboy
- 1221 Views
Last post by Frankentruck
- 4546 Views
Last post by clm
- 1247 Views
Last post by RogueIV
- 616 Views
Last post by slotcarrod
- 1162 Views
Last post by Moggie XL
- 1028 Views
Last post by askbob
- 553 Views
Last post by longboardnj
