Cvd for rc10 original
- Has thanked: 35 times
I need a cvd set for and rc10 vintage build. I tried using the MIP cvd set and while it's a quality item, it is either too sort or I need to limit my shock travel length. I'm using the 3/16" axles and need a longer dog bone/center shaft. JC Racing has a +2 but there's got to be an alternative to waiting 3 weeks on a maybe. I've been scouring this site and am coming up short. Any info or link would be greatly appreciated.
- Has thanked: 1243 times
- Been thanked: 639 times
Re: Cvd for rc10 original
Customworks shortsLiveaxle wrote: ↑Tue Nov 05, 2024 10:46 am I need a cvd set for and rc10 vintage build. I tried using the MIP cvd set and while it's a quality item, it is either too sort or I need to limit my shock travel length. I'm using the 3/16" axles and need a longer dog bone/center shaft. JC Racing has a +2 but there's got to be an alternative to waiting 3 weeks on a maybe. I've been scouring this site and am coming up short. Any info or link would be greatly appreciated.
https://www.customworksrc.com/product/mip-cvd-kit-short/
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
I use that Custom Works Short kit (CSW7210) and with the shims it has, I get good outdrive engagement. It is an MIP CVD kit that has been repackaged as Custom Works.
For your MIP CVD setup, where are the shims? Are they all on the wheel side of the axle? Maybe some they need to be moved to push the dogbone further into the outdrive. What sort of condition are the outdrives in? Any wear at the ends? Are you running any spacer in the rear shocks? They are supposed to have one per the manual (not mx possible stroke length).
I recall reading that the new diff was a different width. Are the reissues MIP shafts built for those?Frankentruck wrote: ↑Tue Nov 05, 2024 1:28 pm I use that Custom Works Short kit (CSW7210) and with the shims it has, I get good outdrive engagement. It is an MIP CVD kit that has been repackaged as Custom Works.
- Has thanked: 1129 times
- Been thanked: 3917 times
the width related to between the bearings and its only a couple shims worth. AE rere CVA's were notoriously short, I hope MIP didnt just copy those
I have the shims on the axle side in an attempt to get as much engagement as possible. The outdrives are NOS and in new condition. As far as spacer, I'm in the works of putting limiters inside the shocks if need be , but want to avoid that for full (or near full) articulation. A longer mid shaft would make it right. Measurements on MIPs other cvd mid shafts would be my next move. ThanksFrankentruck wrote: ↑Tue Nov 05, 2024 1:28 pm I use that Custom Works Short kit (CSW7210) and with the shims it has, I get good outdrive engagement. It is an MIP CVD kit that has been repackaged as Custom Works.
- RogueIV
- Has thanked: 2135 times
- Been thanked: 1100 times
Even with the original dogbones you need to significantly limit the down travel. What rear shock shafts are you running? The original 1.32" shafts required a 5/8" internal spacer. Also make sure you have your camber set (usually around -1 to -2 degrees) as this effects engagement as well.Liveaxle wrote: ↑Sat Nov 09, 2024 7:30 amI have the shims on the axle side in an attempt to get as much engagement as possible. The outdrives are NOS and in new condition. As far as spacer, I'm in the works of putting limiters inside the shocks if need be , but want to avoid that for full (or near full) articulation. A longer mid shaft would make it right. Measurements on MIPs other cvd mid shafts would be my next move. ThanksFrankentruck wrote: ↑Tue Nov 05, 2024 1:28 pm I use that Custom Works Short kit (CSW7210) and with the shims it has, I get good outdrive engagement. It is an MIP CVD kit that has been repackaged as Custom Works.
- 1092 Views
Last post by mdutcher
- 1095 Views
Last post by Sunseeker
- 1633 Views
Last post by uniquenamehere
- 746 Views
Last post by binjaloo
- 1003 Views
Last post by JK Racing
- 643 Views
Last post by phoenix
- 2598 Views
Last post by mikea96
- 2080 Views
Last post by stingerrray
Users browsing this forum: juicedcoupe,
Tbot [Bot] and 2 guests
