MIP CVD for vintage RC10
- Regular Member
Has anyone tried using the MIP CVD bones for a vintage RC10 with the B4 style cvd axle shafts to use modern B4 hex wheels? You could even use the T4 hex's to make it a little wider if you desired. Thought i'd throw this out there to see if anyone tried it before I shelled out the $40 to find out it didn't fit!
Bitten by the R/C bug for the 2nd time...Team Associated until I die...
Re: MIP CVD for vintage RC10
http://www.rc10talk.com/viewtopic.php?f=35&t=17844&start=30
This is the best work through to get B4 hardware on an RC10
- Been thanked: 81 times
Are not all b4 axles the same lenght outside the hub ? b4 to sc10 ? Self clamping b4 hexs should work no?
- uniquenamehere
That particular build used B44 CVDs... I did the same thing:ck33 wrote:http://www.rc10talk.com/viewtopic.php?f=35&t=17844&start=30
http://www.rc10talk.com/viewtopic.php?t=29737
- 746 Views
Last post by binjaloo
- 2610 Views
Last post by mikea96
- 1019 Views
Last post by juicedcoupe
- 4254 Views
Last post by Dual
- 576 Views
Last post by carloco8
- 700 Views
Last post by Hillbillyrcer
- 1015 Views
Last post by SRBMOJO
- 1558 Views
Last post by littleVETTE
