RC12L Rear Hub question
I have an RC12L that is missing the rear diff hub. I see original examples for sale on eBay but they have the two hole wheel mounts. My question is: can I swap out the RC12L hub with one for an 12l4 or are they too different?
- camlchris
- Been thanked: 4 times
Re: RC12L Rear Hub question
the old 12L is using a 2 holes hub to mount the rim, while the modern 12L4 / 12R are using 3 holes hub. They are totally different and not inter-changeable.
Thanks. I've done a bit of homework since posting this question. The 12l diff hub isn't drilled. The diff-side wheel is held in place via friction fit. The hub on the other side can be replaced with a friction fit hub so that it can accept newer 3 hole wheels. Of course, until I take all of the parts off of my other cars and test it, this is all theory...
- teman
- Been thanked: 6 times
I got it to work in the past, but you have to swap everything including axle, rings and both hubs.
-Kevin
- bearrickster
the 12L3 or 12L4 rear axle assm. will work in a 12L I have most of my cars done that way.
- 1333 Views
Last post by treehugger
- 22 Replies
- 4604 Views
Last post by mdutcher
- 764 Views
Last post by cautrell05
- 1215 Views
Last post by MONSTER
- 2897 Views
Last post by DerbyDan
- 734 Views
Last post by m_vice
- 660 Views
Last post by broodenburg
- 835 Views
Last post by juicedcoupe
Users browsing this forum: Mojeek [Bot] and 2 guests
