RC10 wheels on a JRX2?
MelvinsArmy
Been thanked: 11 times
Post by MelvinsArmy »
Anybody ever put RC10 wheels on a Jrx2? If so, what parts did you use? I assume the fronts are easy, just get different bearing sizes, but what about the rears?
tulsa
Re: RC10 wheels on a JRX2?
Post by tulsa »
MelvinsArmy wrote:Anybody ever put RC10 wheels on a Jrx2? If so, what parts did you use? I assume the fronts are easy, just get different bearing sizes, but what about the rears?
all i did was drill out the rear wheels (or hubs in my case)
http://www.rc10talk.com/viewtopic.php?f=5&t=3441
the backspacing is gonna be off. they'll stick out little more.
MelvinsArmy
Hmm, wheel modifications aren't really an option for my case. I'm was thinking of putting my Tecnacrafts on my Jrx2. Anybody got some minty Jrx2 Tecnacrafts they might want to trade for some RC10's?
johnqpublic
Post by johnqpublic »
You could probably use a set of Raborn axles, and just use 1/4 x 3/8 unflanged bearings in your Losi hub carriers. I have used a similar set-up with JRX Pro (A2038) hub carriers and RC10 1/4" axles. I may have a new set of those axles if you're interested, I'll take a look.
johnqpublic
These are the axles I'm talking about.
mrlexan
Post by mrlexan »
Will the bearing/hub combo still work with those axles? The look to large in OD to me.
www.gojammedia.com
johnqpublic
They are 1/4", just like RC10 axles...only difference is they are made to use Losi style slider axles. There is also an insert that fits into the outdrive of the Associated transmission to accept the universal/sliders.
johnqpublic
Here is a pic of the whole set up. (Thanks Tulsa)
http://www.dirtoval.com/forums/showthread.php?t=28708&highlight=raborn
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
Here are the ones I recently bought from tulsa:
Come and visit the stable
tulsa
Post by tulsa »
johnqpublic wrote:Here is a pic of the whole set up. (Thanks Tulsa)
glad to help out :lol: paul if you have any losi stuff left over pm a pic of all of it.
scot...............
highwayracer
Been thanked: 6 times
Post by highwayracer »
mrlexan wrote:Will the bearing/hub combo still work with those axles? The look to large in OD to me.
The stock losi bearings will not fit with those axles. Depending on the width of the losi hub, you will have to use either the 1/4 flanged or non-flanged (rc10t) bearings. The outer diameter is the same, but the inner diameter is different.
regards,
highwayracer
i have the raborn sliders with losi h-arm carriers on my c.c. oval car. you just need to use 1/4 x 3/8 plain bearings.
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
Or you could get the big-bearing RPM rear hubs and use 1/2" x 1/4" bearings.
Return to “Losi Forum”
Users browsing this forum: No User AvatarMojeek [Bot], No User AvatarTbot [Bot] and 4 guests
