JRX2 or Pro wheels
Triniboy
JRX2 or Pro wheels
Post by Triniboy »
Hi Guys
I've passed over my JRX Pro to my nephew as its the only car I could bare to let him drive since he drove my MR4BC into a wall and broke the bulkhead cover and shock tower. I was looking to get some help on two points
1. What direct fit wheels would fit this model?
2. What are the best tyres for hard surfaces I have some mini pins in a soft compound but I am experiencing lots of wheel spinning. Any ideas to improve this?
Varma
PS the MIP gearbox if awesome and the car is etremely fast with a 17t yokomo stock motor.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: JRX2 or Pro wheels
Post by JK Racing »
someone correct me if i am wrong, but current losi/b4 rear wheels should be a direct fit, an b4 front rims?
Triniboy
Post by Triniboy »
Cheers JK
I will try them I should have earlier but I sold my XXX4 to Tom (Stacey) before trying them. I did get alot of wheels with the car including an unused but mounted set of orange JRX2 wheels if I could get some fronts I would use them as I think think they look awesome.
Brandon G
Post by Brandon G »
JK Racing wrote:someone correct me if i am wrong, but current losi/b4 rear wheels should be a direct fit, an b4 front rims?
I believe you are correct on both counts!
2lb-racing
Post by 2lb-racing »
not for the B4 rear wheels only the front wheels fits directly, for the rear you need to cut the wheels, the ofset is different
RETRO R/C
Has thanked: 11 times
Post by RETRO R/C »
Duratrax evader wheels bolt straight on.
Used them in the enduro on my JRX Pro recently.
Cheers
Darryn
TO KNOW WHERE YOU ARE GOING - YOU HAVE TO KNOW WHERE YOU HAVE BEEN
VENOM International | Factory Pilot - Team SCHUMACHER UK | J-Concepts USA | B-Fast Performance USA | Bugle Boy Racing | MAX Racing Products International
Triniboy
Post by Triniboy »
Cheers Guys/Darryn
The Evader wheels might be cool also as I find the chassis on the JRX Pro quite long so the larger wheels would be easier to use and obviously more available. Thanks again guys.
Return to “Losi Forum”
Users browsing this forum: No User AvatarGoogle [Bot] and 7 guests
