Please expain worlds front end
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Hey all. Can someone please explain the Worlds front end? Does this describe a certain setup? Truck nose plate with associated parts? Or is it the RPM kit? Or just a general long arm conversion?
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
Re: Please expain worlds front end
There's the RPM "World's 91" setup that uses a truck noseplate (on a tub chassis) or on a RPM Ultra Molded chassis. The regular Associated World's setup is just a different shock tower with only three holes per side.
- Has thanked: 36 times
- Been thanked: 1318 times
you can use the worlds conversion on anything with the narrow truck sized front kickup. the rpm ultra molded (as temple stated), composite craft "worlds", andy's pro race, or you can make one yourself from a standard buggy chassis.
here's an arm length comparison to a stock ae wide track arm.
- Attachments
- IMG_2431.JPG (128.48 KiB) Viewed 1633 times
- Has thanked: 183 times
- Been thanked: 157 times
heres a comparison of a worlds compared to a standard setup.
the overall width is the same, but theres alot more arm in the worlds setup.
also a pic of standard buggy, worlds, and rc10t arms.
- RichieRich
Ok, thanks big time for the pictures.
So, front track stays the same, just more suspension travel. It appears the rear track gets wider with those arms. Those arms are RPM parts, right?
- mrlexan
- Been thanked: 12 times
Roll center and motion ratio change as well.
www.gojammedia.com
www.gojammedia.com
rear track width with the rpm worlds stays the same since you have to narrow the chassis to mount the arms further in.RichieRich wrote:Ok, thanks big time for the pictures.So, front track stays the same, just more suspension travel. It appears the rear track gets wider with those arms. Those arms are RPM parts, right?
- MOmo
I was curious about this myself. I have a CF 10T Shock tower and was thinking about whether or not to use it on my RPM chassis OR I Could use it on my 10T as the front shock tower.
I also received in some spares from James (BikerBob) a larger front shock tower and wondered if it was an actual WORLDS shock tower. It does have the 3 holes on it.
Also- as an aside, Im wondering if folks out there have a copy/scan of the various shock towers. Im looking for the true RPM, WORLDS and any other unique Front and rear shock towers. Im asking because i have an acquaintence who works for a local plastics ship and if i can find and create a template, I may be able to reproduce some of these popular towers in plastic/fiberglass material. Initially my interest was purely selfish, but knowing many of my sister and brethern were looking for certain parts, like towers, i might try and see if i can get them made in larger quantity.
MOmo
MOmo
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Does anyone know if the RPM team car rear end kit is much different than the World's rear end kit? I located one last week and could'nt remember whether it was similar or not.
This is all very interesting!
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Just to clarify: AE World's car has the exact same geometry (front and rear) as a Team Car. Now if you are refering to the RPM narrow chassis conversion, aka "world's", the rear end differs from the Team Car in that the rear a-arms are longer, but the chassis is narrower to compensate. There are plenty of threads here that will help you figure it out with pictures.
Come and visit the stable
- a01butal
OK, Thanks Asso_man! I'll check it out.
- 623 Views
Last post by Jackson
- 19 Replies
- 3505 Views
Last post by flipwils11
- 2766 Views
Last post by sandkil
- 1122 Views
Last post by klavy69
- 947 Views
- 865 Views
Last post by cautrell05
- 528 Views
Last post by tulsa
- 589 Views
Last post by tulsa
