B2/B3 front end
General info, Q&A.
fredswain
B2/B3 front end
Post by fredswain »
I was searching through the forum to see if it was possible to retrofit a B2/B3 front end on an original RC10 but came up short. I found the buggy build that has the original front end on a T2 chassis but I haven't found the reverse. Someone must have done it or at least know the answer. So, can it be done and if so, how well does it work?
Re: B2/B3 front end
haven't seen anyone do it. i don't forsee it working out all that great.
cautrell05
Re: B2/B3 front end
Post by cautrell05 »
From the pictures I have seen the nose plate mounting pattern looks similar to the originals. Im sure they are different but it would be nice to see them side by side to know for sure.
Example-
http://cgi.ebay.com/Associated-B3-Front-Kickup-RC10b2-/200619317981?pt=Radio_Control_Parts_Accessories&hash=item2eb5d7dadd
Nick
Re: B2/B3 front end
ya, it looks similar, but they're not the same.
Re: B2/B3 front end
it can be done if you use all B2/B3 parts except for the nose plate, and make your own noseplate to match up with the gold pan mounting pattern. you will have to get creative with the upper brace mounting to the chassis.
here is a scratch build I did, you can see the B2 front end parts and how they fit together.
http://www.rc10talk.com/viewtopic.php?f=40&t=16813
Users browsing this forum: No User AvatarBing [Bot] and 3 guests
