Rc10 stealth gear box
- Has thanked: 149 times
- Been thanked: 20 times
Is associated #6571 the correct top shaft for the stealth buggy trans? And does the 10t use the same shaft? Looking at some online docs can get confusing
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Rc10 stealth gear box
Yes- and it was used from the first stealth through the DS, B3/T3 and GT as well.
If you want to modernize, Avid makes a topshaft to run the dual disk stuff and they make a slipper assembly that will be great on the wallet vs sourcing vintage parts
https://www.avidrc.com/product/5/accessories/3506/Associated-Aluminum-Topshaft-B4-Stealth-AV10062-accessories.html
https://www.avidrc.com/product/5/accessories/2763/Triad-Evo-Slipper-Mod-8184-B62-AV1020-4-MOD-accessories.html
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2095 times
Edit: What he said.
The same input shaft was used in all Stealth transmissions through the B/T3. As such, the larger B/T3 (and later GT) slipper can be used on earlier cars.
The transmissions from the 10T, Team Car, Stealth CE, DS, and Worlds cars are basically the same.
Re-re Worlds cars have a revised case and idler gear. They also use a B4 input shaft and V2 slipper. The V2 slipper is a little better but the earlier case and idler is far better.
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Yes, someone noticed that the original Stealth tranny didn't provide enough drag and was far too quiet so they fixed that with the re-re.juicedcoupe wrote: ↑Tue Feb 21, 2023 2:50 pm ...Re-re Worlds cars have a revised case and idler gear. ...
XLR8 wrote: ↑Tue Feb 21, 2023 9:12 pmYes, someone noticed that the original Stealth tranny didn't provide enough drag and was far too quiet so they fixed that with the re-re.juicedcoupe wrote: ↑Tue Feb 21, 2023 2:50 pm ...Re-re Worlds cars have a revised case and idler gear. ...![]()
- Has thanked: 49 times
- Been thanked: 73 times
Thanks for the info!GoMachV wrote: ↑Tue Feb 21, 2023 2:44 pm Yes- and it was used from the first stealth through the DS, B3/T3 and GT as well.
- 680 Views
Last post by shane
- 2122 Views
Last post by minimini
- 746 Views
Last post by BWX
- 1575 Views
Last post by jeepy2013
- 624 Views
Last post by Junkinthetrunk
- 314 Views
Last post by Group B
- 1485 Views
Last post by THUNDERSTRIKE1
- 855 Views
Last post by ireg
Users browsing this forum: Dual and 15 guests
