Help with old 2.19 gear box clicking
sgirouard
Post by sgirouard »
I'm hoping someone has an idea on this one. I have a XX and had a JRX2 do the same thing. The gear box clicks. I've pulled it apart and can't find a single flaw in it. The teeth are perfect, the ball diff is very smooth. The case is perfect.
Anyone know what causes this?
slapshot1979
Re: Help with old 2.19 gear box clicking
Post by slapshot1979 »
Hockey card stuck in the spokes?? :lol: Is this installed hooked to axles and motor ?? Ive had a few of these gearboxes over the years and never had this?
sgirouard
Post by sgirouard »
Sorry, what do you mean "hooked to axles and motor"?
slapshot1979
Just looking for more info, is this installed in the car ready to run, or on the bench and you feel clicking when turning over by hand??
Been thanked: 1319 times
is it the trans..... all by itself that's clicking? are you spinning the entire rear drivetrain without the motor and hearing the clicking?
Has thanked: 359 times
Been thanked: 470 times
I have heard the backlash make clicks before-
Love the hockey card in the spokes :lol: what is this hockey?
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
Most the time its the wheel axle pin poping or clicking in the back of the wheel.DON
sgirouard
Post by sgirouard »
Thanks for the clarification.
This doesnt happen under free spin (no motor) or if you apply power with the vehicle off the ground, it only happens when I apply throttle and the vehicle is on the ground. It seems to drive just fine with the clicking, it's just one of "those things" I hate to hear. LOL
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Post by mytimac »
I am going to guess your driveshafts are hitting the arms in some way maybe. At least something with the driveshafts or axles. That would explain only when on the ground and you have a load on the shocks making the arms and driveshafts change angles. Maybe one of those pins in the axle joints?
sgirouard
Post by sgirouard »
Good call. Makes sense. I'll look at that tonight. I keep going at the gear box looking for solutions.
PS THANK YOU FOR CHANGING YOUR AVATAR.
As the father of 3, I had my share of those noses and cringed everytime I saw your avatar LOL.
morpheus2010
Post by morpheus2010 »
Used to put a small piece of silicon tube in the drive cups to stop the T bar rattling about. That may help.
THUNDERSTRIKE1
Sometimes if idler is used and gets put back in traany but in the oppisite direction it was going before it clicks or tries to bind causing the click.If it is take it apart turn it around reinstall and tranny is way smoother again.Ive had three like this i got in recent deals.DON
Return to “Losi Forum”
