What's the latest slipper upgrade route?
cobrakai
Post by cobrakai »
My RC10GT brushless conversion still has the original slipper. The spur gear is kind of "wobbly" as the assembly doesn't sit perfectly against the split pin, and the clutch is a very narrow thin ring around the perimeter of the clutch pad with very little adjustment range. It's almost fully locked out to prevent slipping from the torquey motor and I don't want to strip out my tranny.
I was looking into the B4.2 slipper upgrade but it's looking like most parts are NLA.
Is there another slipper I can retrofit? Something generic or from another brand that might fit nicely? I can machine any needed adapters.
Re: What's the latest slipper upgrade route?
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
Another option is to replace the drive pin and assembly with a B3 slipper. When installing the drive shaft roll pin put the slit facing the motor plate.
The TX SKUNK
Has thanked: 269 times
Been thanked: 2094 times
jcwrks wrote: Wed Jan 18, 2023 11:31 am Another option is to replace the drive pin and assembly with a B3 slipper. When installing the drive shaft roll pin put the slit facing the motor plate.
Doesn't the GT already have the larger V1 slipper clutch?
jcwrks
Post by jcwrks »
juicedcoupe wrote: Wed Jan 18, 2023 11:51 am
I thought the early GT's had the original 2.25 slipper, but I could be mistaken.
* edit: Found this 1999 manual on AE's site. Fig 87 references two old 2.25 p/n's, and Fig. 90 shows the old parts installed. I'd imagine the 1993 manual also has the old slipper parts listed.
https://img2.associatedelectrics.com/pdf/cars_and_trucks/RC10GT/Team/tubGT_manual1a.pdf
The TX SKUNK
cobrakai
Post by cobrakai »
My GT is the RTR model from circa 2001.
The clutch looks like this. Never been a big fan of it. I'd like a beefier clutch that I can have the spring more like 50% compressed so I have adjustment range.
https://thumbs.worthpoint.com/zoom/images1/1/0113/25/team-associated-rc10gt-complete_1_5c9cd453ce3b68b76f90ee394dcf6994.jpg
Is there any way I can use my steel top shaft instead of the aluminum avid one?
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
You can try an get a Carbon fiber disk cut to the slipper size. similar to kid again slipper offering.
AS well since you have an eGT this link will apply,
https://www.rc10talk.com/viewtopic.php?f=38&t=47926
the b4/t4 had a steel stopshaft but those are getting pricey to source.
jcwrks wrote: Wed Jan 18, 2023 11:59 am * edit: Found this 1999 manual on AE's site. Fig 87 references two old 2.25 p/n's, and Fig. 90 shows the old parts installed. I'd imagine the 1993 manual also has the old slipper parts listed.
Mine is the newer flat chassis type, which used the B/T3 slipper.
cobrakai
Post by cobrakai »
scr8p wrote: Wed Jan 18, 2023 3:40 am https://www.avidrc.com/product/5/accessories/3506/Associated-Aluminum-Topshaft-B4-Stealth-AV10062-accessories.html
https://www.avidrc.com/product/5/accessories/452/Triad-Evo-Slipper-Mod-8184-B6-B443-22-AV1020-MOD-accessories.html
Since it's for a truck, I went with that slipper setup because it comes with the larger spur gears. They have other kits with smaller ones.
Do you have a picture of it installed?
I have various modifications to my truck so I am hoping things will still line up.
cobrakai
Post by cobrakai »
After looking at the Triad slipper some more...
The gear is 48 pitch. The GT came with 32 pitch gears. I am currently running a 21/60 combo. The equivalent size 48-pitch spur is 90T and I'd have to change my pinion to a 32T to mesh.
KidAgain
Business Member
Has thanked: 513 times
Been thanked: 431 times
Post by KidAgain »
If she takes a #6585 slipper you can use one of my Carbon Slipper pads bud.
Return to “RC10 Truck Forum”
