Junk worn out brushed motors
Has thanked: 2477 times
Been thanked: 2784 times
One of the reasons I dislike brushed stock motors is the non-rebuildable construction. I know an endbell can be popped off, but it doesn't usually go back on well or fit tight again. So I have a bunch of worn out motors that I'm thinking about putting in the trash. Some have shorts and overheat, some are split open, some have horrible squealing bushings. I don't know what else to do with them. Anyone have any other thoughts?
Dadio
Has thanked: 2697 times
Been thanked: 2234 times
Re: Junk worn out brushed motors
Post by Dadio »
The bearings can be replaced with ball bearings , might have sort of done it back in the day but there's no proof guv :roll:
The problem is, once the endbell is removed the crimp isn't a good fit anymore after reinstall. I used to try that to 'improve' my motors. Rules are meant to be broken... but it was my motors that ended up broken.
Has thanked: 264 times
Been thanked: 2013 times
I don't bother much with closed endbell motors. I'll flush them out and oil the bushings. If that fails, they are trash.
I've rebuilt several "tab" style motors. I just use a automatic center punch to lock the tabs back down.
https://www.harborfreight.com/spring-loaded-center-punch-621.html?utm_source=google&utm_medium=cpc&utm_campaign=12169518939&campaignid=12169518939&utm_content=114845716057&adsetid=114845716057&product=621&store=790&gclid=Cj0KCQiA37KbBhDgARIsAIzce17pBmTZRzQRvXTa_d6hQ6WDM84etzpw1qj7fsGVFnGfcgjAitX2hfcaAh8NEALw_wcB
Has thanked: 1080 times
Been thanked: 3730 times
Hahaha! You beat me to it :lol:
I used to use an automatic punch to reset the tabs. It will leave a dimple but shocks the tab back into place pretty nicely. I use this punch for a lot of things, even for knocking out stubborn hinge pins.
Toaster
Has thanked: 473 times
Been thanked: 136 times
Post by Toaster »
As I rarely run my cars anymore, most of time I just throw them into my shelf queens :) please don’t chuck the Reedy competition or the 240, am sure they could be retired to the shelf somewhere.
I come for the RC10's but stay for the Yokomo's :P
Current projects:
1993 WCS Faux-komo
1994 Yokomo Box-Art
RC10GT Restoration
morrisey0
Has thanked: 74 times
Been thanked: 1742 times
Post by morrisey0 »
Toaster wrote: Thu Nov 10, 2022 6:45 pm As I rarely run my cars anymore, most of time I just throw them into my shelf queens :) please don’t chuck the Reedy competition or the 240, am sure they could be retired to the shelf somewhere.
This was my first impression also. You have a few there that would clean up nice and play the part on a shelf queen.
I don't give up on motors until they're basket cases. The Competition Stock is intent on being a smoker. The 240ST had some running issues and is rusty. If someone has a use for a box of non-runner motors, PM me a mailing address. Most of them don't have springs, brushes, or brush screws.
