rear hubs??
General info, Q&A.
chophead69
rear hubs??
Post by chophead69 »
I am building a new rc10 from new all black parts.I got the rear hubs part number 7365 well after I got them I tryied putting the flanged bearing in and the axle but the don't give me enough room for the pin to go threw or allow for the shims.I looked at my worlds rear hubs and my graphite well they are different from the 7365.I got them because they said they are for the rc10 .if I use unflanged bearings they fit but the axle shaft is to big.the in side dia is for my axle is 1/4 so is there a bearing for them that are unflanged or do I have the wrong hubs?
My pop always said i had to many iron's in the fire
Been thanked: 3919 times
Re: rear hubs??
You have truck rear hubs, use 1/4x3/8 unflanged bearings
chophead69
Re: rear hubs??
They will work then for the buggy?will I have any issues with the cvd's bottoming out?like I said before they were listed as rc10 but then different sellers list them as rc10 gt. I did just found out they are the wrong hubs.the part number for the worlds rear hubs say they are 1.5 degree are they better to use then for traction? Or should I just use the ones I got already? Thanks gom
Re: rear hubs??
I can't speak for the angles, that's for the setup guys. I will say tho that they will work just fine with the right bearings.
THUNDERSTRIKE1
Re: rear hubs??
Post by THUNDERSTRIKE1 »
10t hubs work for buggy an truck no issues and on DS cars.Shim enuff so axles stay in outdrives and shim enuff on outside of hub for axle slop or wheel wobble in and out when running.don
chophead69
Re: rear hubs??
I just gotta get the right bearing now cause I have the flanged bearings
