RPM rear hubs
- bully
- Been thanked: 6 times
RPM rear hubs
Hi all, what crush tube or bearing spacer are guy's using in between the hub bearings with the RPM70272 rear hubs?
Any help appreciated
- Has thanked: 36 times
- Been thanked: 1319 times
Re: RPM rear hubs
i don't have crush tubes in mine. theres a healthy lip that the bearings sit on, didn't think they were needed.
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
Re: RPM rear hubs
i used stock carrier tubes, and thin cvd spacers to get the perfect length. you have to open the plastic spacers with a dremel if you use the rpm bearings for 3/16 axles... you could crank the axle nuts down with a impact gun and still have them spin with silk ease, not that i do... but i hate having anything bind, they use the spacers for a reason, my gt's rear freewheels for what seems forever.... ahhhhhh soo smooooth..
- 3790 Views
- 832 Views
Last post by juicedcoupe
- 1222 Views
Last post by chophead69
- 1027 Views
- 1439 Views
Last post by JK Racing
- 1048 Views
- 966 Views
Last post by JosephS
- 1217 Views
Last post by stickboy007
Users browsing this forum: DotNetDotCom.org [Bot] and 1 guest
