Wheel Discs
HawkeyeLTS
Has thanked: 9 times
Been thanked: 64 times
Wheel Discs
Post by HawkeyeLTS »
Are these just wheel caps like the Losi cars had?
I really like the look on this truck, Id like to put some on my T2
Anyone have any info? If they are caps which ones fit the stock T2 rims?
Thanks!
Re: Wheel Discs
Round stickers.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Wheel Discs
Post by RC10th »
AE and Yokomo made them in various colors..... now they go for some good money which isn't worth it since you need to remove them every time you take a wheel off.
It's easy to make your own, grab some Top Flite TrimKote (adhesive) from the model shop and an olfa circle cutter and make your own. Here's a couple of what's left when I made a bunch for my oval car and stadium trucks. Make sure you get a rubber foot if you want a solid disk to prevent the pin from spiking the center.
The far left ones are silver but it's hard to tell in the photo. The far right 2.2 disk is a paper sample to check for size before cutting the actual TrimKote.
HawkeyeLTS
Re: Wheel Discs
Thanks guys, I saw some Yokomo wheel stickers that MCI racing is making.
Makes sense now thats what they are.
That would work on a shelfer since I wont be taking wheels off.
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: Wheel Discs
Post by JosephS »
Is this a cosmetic thing or was there a performance angle to it?
I think got a set of wheels that are supposed to go with these kind of caps with a trade.
Has thanked: 2605 times
Been thanked: 2979 times
Re: Wheel Discs
It keeps dirt / mud from collection in the crevices of the wheels. That could make make wheels heavier and unbalanced. The backside disk is probably more beneficial.
HawkeyeLTS
Re: Wheel Discs
Can you put them on the stock wheels?
so they would just stick to the edge, the inside would be hollow because of the shape of the wheel.
RC10th
Re: Wheel Discs
Post by RC10th »
Correct, they just stick to the lip of the rim.
Think of them as the precursor to the flat faced/aero rim.
JosephS
Re: Wheel Discs
Post by JosephS »
I came across these from MCI
1/10TH ASSOCIATED - 58MM WHEEL DISC DECALS
This may work for those not inclined to cut their own.
HawkeyeLTS
Re: Wheel Discs
JosephS wrote: Wed Apr 13, 2022 1:58 pm I came across these from MCI
I noticed those too, I'm going to order some of those and get them solid, no hole in the middle.
Dirtburner
Has thanked: 61 times
Been thanked: 123 times
Re: Wheel Discs
Post by Dirtburner »
HawkeyeLTS
Re: Wheel Discs
I ordered some from MCI ill give them a shot
HawkeyeLTS
Re: Wheel Discs
Put them on my T2.
I think its a cool look, something different.
If the rims have some scuffs and scratches I could see the stickers not staying on.
Return to “RC10 Truck Forum”
