Need help identifying wheel hub. 834 hotshot wheel adapter?
rccars4sal
Post by rccars4sal »
Allright, so these are supposed to be yokomo to hotshot wheels hub adapter. Problem, the axle hole is 6mm diameter. Now mx4 and mr4 would have 6mm axles, but they are locked to the hub with a pin. These use a set screw like yz10 870c. However, the yz10870c cars use 5mm wheel axle. They do fit hotshot wheels though. Wondering if anybody knows who made them, and if they are missing a sleeve for the inside,, or if theyre not for yokomo, then for what car? Thanks!
Pictured next to 870c axle hub. Click pic to go to the photobucket for more views on this part. Thanks again.
rccars4sal
Re: Need help identifying wheel hub.
So, can anybody confirm axle size on 834 based cars?
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Post by Y'ernat Al »
rccars4sal wrote:So, can anybody confirm axle size on 834 based cars?
Your lucky day. Have it right here on the wall..
Front calipers to 0.157, so 4mm.
Rear calipers read 0.196, so 5mm.
- Brian -
My Gallery
rccars4sal
Re: Need help identifying wheel hub. 834 hotshot wheel adap
Thanks for checking that! Still not a match then.
Return to “Yokomo Forum”
Users browsing this forum: No registered users and 15 guests
