Turnbuckle Woes
- hav3rchuck
- Regular Member
- Has thanked: 9 times
Turnbuckle Woes
Hi all. I am looking for a bit of advice.
I am in Germany trying to find a turnbuckle set (including balls and cups) for my Cadillac RC10, but having a real tough time finding the 4-40 set here (or it is super expensive if so).
I can get a lot of AE parts, turnbuckles, etc, but aren't they latest RC10 models metric based?
Do you have a good alternative that could work for them as well? Just trying to avoid dropping $70=80+ (shipping + VAT is killer) just for some freaking turnbuckles on a VERY old car that I am trying to just drive as a basher with my son.
Thanks for the help in advance!
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Re: Turnbuckle Woes
Schumacher.
4.3mm ball and cup size. Anything larger will likely interfere in the front. Don't use RPM cups, they are too bulky.
You can use common 3mm turnbuckles, in the correct lengths.
- hav3rchuck
- Regular Member
Re: Turnbuckle Woes
what about these? https://www.associatedelectrics.com/teamassociated/parts/details/91722-ASC91722-rc10b6_ballcups/ ? I wish they would say what size they actually are...
- juicedcoupe
Re: Turnbuckle Woes
Too big.hav3rchuck wrote: ↑Sat Feb 26, 2022 8:26 pm what about these? https://www.associatedelectrics.com/teamassociated/parts/details/91722-ASC91722-rc10b6_ballcups/ ? I wish they would say what size they actually are...
The only ones that I know that fit are some Schumacher, Custom Works, and CRC.
What you want is 4.3mm, which isn't commonly used anymore.
- Has thanked: 1243 times
- Been thanked: 639 times
Re: Turnbuckle Woes
Finding white ball cups is hard they are hard to find and a bit expensive.hav3rchuck wrote: ↑Sat Feb 26, 2022 5:50 pm Hi all. I am looking for a bit of advice.
If you are going for vintage you can get steel threaded 4-40 rod and cut it on your own.
- hav3rchuck
- Regular Member
Re: Turnbuckle Woes
I am going the route if 'I want this guy to run'
They don't need to be the original hardware. So if they are black, white, orange, pink cups, it is fine to me (I might need to get a new shell to match is all
It is why I am also open to using different sized hardware that will still fit.
- 966 Views
Last post by kaiser
- 929 Views
Last post by adam lancia
- 782 Views
Last post by Jimtencubed
- 25 Replies
- 3004 Views
Last post by chophead69
- 1141 Views
Last post by rccars4sal
- 2586 Views
Last post by yellowdatsun
- 1263 Views
Last post by Brandon G
- 835 Views
