T3 axle question
mikesofunny
Has thanked: 194 times
Been thanked: 48 times
T3 axle question
Post by mikesofunny »
I'm new to Associated stuff, please bear with me. I know there are 3/16" & 1/4" rear axles, but what about these stubs that are both? I thought the 1/4" axles/wheels were 1/4" all the way through? Clearly these wheels are made for these axles since they even have a tapered part that meshes with the stub. But when going to buy replacement axles or wheels, what do I have?
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: T3 axle question
Post by JosephS »
mikesofunny wrote: Fri Jan 14, 2022 4:31 pm I'm new to Associated stuff, please bear with me. I know there are 3/16" & 1/4" rear axles, but what about these stubs that are both? I thought the 1/4" axles/wheels were 1/4" all the way through? Clearly these wheels are made for these axles since they even have a tapered part that meshes with the stub. But when going to buy replacement axles or wheels, what do I have?
What you have in the picture is the 1/4" stub axle. The axle is 1/4" with a tapered end for securing the wheel nut. If the wheel fits the pictured axle it is a 1/4" wheel.
mikesofunny
JosephS wrote: Fri Jan 14, 2022 4:34 pm
Thanks for clarification! I thought the size hole through the wheel determined the "size"
JosephS
Post by JosephS »
mikesofunny wrote: Fri Jan 14, 2022 4:41 pm
I am surprised that was still on the T3.
Has thanked: 2604 times
Been thanked: 2977 times
mikesofunny wrote: Fri Jan 14, 2022 4:41 pm Thanks for clarification! I thought the size hole through the wheel determined the "size"
That axle will need a bearing with a 1/4" inner diameter.
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Post by MarkyDents »
Hey Cru ! Go balls out 8)
mikesofunny
JosephS wrote: Fri Jan 14, 2022 5:30 pm
I scored this T3 in new condition, so it has never seen any abuse. I was considering putting CVDs in it, but sourcing original yellow wheels may be difficult.
mikesofunny wrote: Sat Jan 15, 2022 1:33 am
You'll have a harder time finding new cvd's (without piecing them together) than new yellow wheels.
Return to “RC10 Truck Forum”
