Not knowing anything about the ZX-5, why are there so many lengths?
LA258 60.5mm (Rear)
LA245 62.5mm
LA232 65.5mm
LA231 68mm
LA257 73mm (Front)
ZX-5 Universal-Joint Axle question
- esaresky75
Re: ZX-5 Universal-Joint Axle question
They correspond to the different suspension setups. There are several rear hub/suspension arm combos, as well as variable hinge pin widths. Because of this you might need all these options. There are also two different front hub/steering knuckle setups which require different cvd combos.-Jeff
- Been thanked: 10 times
LA258 are for the spesaresky75 wrote:Not knowing anything about the ZX-5, why are there so many lengths?
LA258 60.5mm (Rear)
LA245 62.5mm
LA232 65.5mm
LA231 68mm
LA257 73mm (Front)
LA245 not sure about that
LA232 Standard ZX5 rear (rtr)
LA231 Standard ZX5 front (rtr)
LA257 FS and FS2 ie for the Losi type front susp.
mvh Isobarik
- 928 Views
Last post by cyber10b
- 3884 Views
Last post by clm
- 722 Views
Last post by bearrickster
- 1048 Views
Last post by Irio - esos
- 963 Views
- 400 Views
Last post by RichieRich
- 1773 Views
Last post by bigmd
- 919 Views
Last post by rc10johnny
