question about 3/16" rear axle
General info, Q&A.
strangersinspace
Post by strangersinspace »
I switched over to the AE 3/16" rear axle to run the 2.2 duratrax wheels. However, the axle does not have the deep recess to put the stock spring into. This causes a little slop in the dogbone setup. Just wondering if anyone else has noticed this or if there is some fix for it.
Here's the part.
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=&FVSEARCH=7378&search=Go
I was trying to find what car uses this part out-of-the-box so I could see how it was assembled, but I can't even find a car that has this part as stock.
I have some shims, so maybe that's the key. I was putting them on the outer part of the axle between the outer most bearing and the axle pin that goes into the wheel. Maybe I'm doing that wrong.....???
Re: question about 3/16" rear axle
put a red shock o-ring in the stub axle and the trans outdrives. if that's too much, just do it on the stub axle.
burnsmonkey
Post by burnsmonkey »
I do as scr8p describes and run o-rings on the trans outdrives, it helps it be less jumpy in there with the o-ring.
strangersinspace
Yes, that seems to work well... thanks for the tip!!
SnoopMaxx
Post by SnoopMaxx »
Is it the same as the Rear Stub Axle #9670 from the B4 RTR ?
Morten Max
the axle from the b4 would be longer, i'd imagine.
SteveK
Post by SteveK »
Will a pan-car front spring fit? They are much shorter and wider than the Associated spring.
SnoopMaxx
Post by SnoopMaxx »
I used a ballpoint spring cut in half on my RC10ce
Morten Max
rc10johnny
Post by rc10johnny »
I've also used different shock travel spacers. Johnny
