Mid 4:10
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
- Has thanked: 1153 times
- Been thanked: 624 times
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: Concept 4:10
It looks like you shot it with a .410
- Has thanked: 3 times
- Been thanked: 13 times
Re: Concept 4:10
That's for sure.
RC10 B3 / RC10 B6.1FL / RC10 B64D / RC10 B74.1D / RC10 T2 / RC10 T6.1
- TheDiamondOne
- Has thanked: 2077 times
- Been thanked: 588 times
Re: Concept 4:10
Possible "Build of the Millenium"! I can vision the final result.
- coxbros1
- coxbros1
Re: Concept 4:10
Going Kyosho Golds because I have them laying around, and they are smooth....trying to use as much stuff as I have without too much wasted purchasing....front idler done....hopefully all plastics will be Associated off-white when done, chassis and noseplate will be Associated gold
- coxbros1
Re: Concept 4:10
Ditching the sub c cells, I want to run this car so wrapped an old lrp 2600mah 2s but staying vintage vibe, fits perfect in the chassis
Repaired the back of this old Tekin that was all melted from soldering. I had it laying around .....3.5mm bullets, now I can just plug the wires in, no soldering, same on the motor side
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Re: Concept 4:10
I really appreciate your fearless attitude Derek.
"Today I'm gonna build an RC10-based 4WD buggy and nothing's gonna stop me!!!"
This will be a very very cool build!
- coxbros1
Re: Concept 4:10
I appreciate the sentiments Doug!....actually your quote was what I was thinking exactly when it all started and I will make sure it's a nice build, on a budget tho, got to really limit spending on this one, money is tight right now but hoping "Thumbs" comes thru with some funding
- K Rob
- Been thanked: 5 times
Re: Concept 4:10
That's awesome!
Quite period thinking I reckon rather than today's stuff which is all so similar.
It's inspired me to do a 4wd trailing arm car.
CML Distribution - FTX - Etronix - Fastrax - Centro
RC Racer Magazine
RC Racer Magazine
- coxbros1
Re: Concept 4:10
Just wasn't happy with the other front suspension....it was too easy...need it to be pure rc10....so I am fabbing up this setup with some short arms and front knuckles Go Mach designed....still got to figure out the bearing size situation but its all gonna work out I think
- Frankentruck
- Has thanked: 2604 times
- Been thanked: 2977 times
Re: Concept 4:10
I know it's additional complication and uses newer vintage parts, but it would be cool to have front axles with 12mm hexes and run 2wd RC10B4.2 front wheels. Or maybe the B4.2 fronts wouldn't be too different from the narrow Yokomo fronts. Really, driven jellybean fronts would be extra cool but they're only made as rollers.
- coxbros1
Re: Concept 4:10
Yup, Still debating the wheel situation but I think it will be smaller diameter wheels 1.6 -2.0ish for an old school look...Frankentruck wrote: ↑Fri Jan 21, 2022 2:29 pm I know it's additional complication and uses newer vintage parts, but it would be cool to have front axles with 12mm hexes and run 2wd RC10B4.2 front wheels. Or maybe the B4.2 fronts wouldn't be too different from the narrow Yokomo fronts. Really, driven jellybean fronts would be extra cool but they're only made as rollers.
Lol
Made some progress, had to redo everything I had done with these arms, steering posts, idler puller had to be moved.....ignore the many colors, that will all be fixed in the end.
I got the front axles in after redrilling the steering knuckles for 10mm bearings and a 62mm dogbone (I only have one I found☹)....got the the proper rear belt on and she fits like a bloody glove!
I was concerned the front suspension wouldn't work out but it looks like it gonna
- Frankentruck
Re: Concept 4:10
Where is that 2S battery going to sit?
- 1949 Views
- 52 Replies
- 13498 Views
Last post by HKS_TRD
- 1600 Views
Last post by GJW
- 19 Replies
- 9134 Views
Last post by lin6499
- 3189 Views
Last post by Bo Wallen
- 22 Replies
- 7612 Views
Last post by j0pp3
- 68 Replies
- 23133 Views
Last post by Garage Hack
- 2314 Views
Last post by j0pp3
Users browsing this forum: Google Adsense [Bot] and 4 guests
