Brushed ESCs and 550 vs 540 motor limits
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
I've seen a few brushed ESCs that advertise they will run 550s but the motor turn limit is usually lower than what 540s it'll run. The Traxxas XL-5 is a good example, 12T 550 vs 15T 540. Why is that? Wouldn't a torquey 550 pull more amps and strain the ESC more than a same-turn 540 would?
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
Re: Brushed ESCs and 550 vs 540 motor limits
It could be that Traxxas knows all about the tuning and characteristics of their fixed timing 12T 550 motor, but nothing about whatever random 540 motor might get installed. That could lead a manufacturer to declare a conservative limit.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
First, turn limits are more like recommendations. Amp draw and cooling will determine the true limits.
Second, the armature on a 550 is longer. So each turn requires more wire than a 540. And while this creates a motor with more torque, they are also rpm limited.
Finally, application. Vehicle weight, gearing, battery capacity, terrain, and even your driving style will factor in.
- 610 Views
Last post by Frankentruck
- 15603 Views
Last post by bully
- 2288 Views
Last post by SMOKE-DOG
- 1164 Views
Last post by juicedcoupe
- 1248 Views
Last post by Sixtysixdeuce
- 824 Views
Last post by ricerscott
- 1365 Views
Last post by vintage racer
- 756 Views
Last post by Hcp22
