Typical 540 brushed motor bearing size?
- SMOKE-DOG
What's the typical bearing size for a 540 motor? I had some old stock brushed motors busted open and the comms cut and I want to replace the bushings with bearings. I'm figuring they are all the same size.
TC showroom: http://tamiyaclub.com/showroom.asp?id=18447
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
Re: Typical 540 brushed motor bearing size?
Not sure of the size, but if you place a brass washer between the bearing and the can no one will no the difference...
This post was for entertainment purposes only. I never cheated... with my driving it wouldn't have helped.
- THEYTOOKMYTHUMB
I'm bored at work and found this thread after some searching. Obviously I can't speak for it's accuracy. Hope it helps.
http://www.rcuniverse.com/forum/m_9489896/anchors_9489986/mpage_1/key_/anchor/tm.htm#9489986
- SMOKE-DOG
That helps, thanks.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
I just replaced the bushings on some brand new Associated motors. I used the 1/8 x 3/8 x 5/32 Metal bearings from Avid RC.
http://www.avidrc.com/product/9/standard-bearings/58/18-x-38-x-532-Metal-R2ZZ-standard-bearings.html
- SMOKE-DOG
Sweet.RichieRich wrote:I just replaced the bushings on some brand new Associated motors. I used the 1/8 x 3/8 x 5/32 Metal bearings from Avid RC.
- 1060 Views
Last post by juicedcoupe
- 852 Views
Last post by amp_driven
- 827 Views
Last post by ricerscott
- 1370 Views
Last post by vintage racer
- 708 Views
Last post by caesar
- 502 Views
Last post by Mad Racer
- 809 Views
Last post by Bottom Feeder
- 879 Views
Last post by Stumpy
