Gearing suggestion for Reedy Radon 2 19T, six-gear
- flatspunout
- Has thanked: 7 times
- Been thanked: 4 times
Running a 54T 32P AE spur. The B4 RTR manual recommends 9.57 as FDR for a 19T motor (I think the original Radon 17T was stock in that car). A 54/10 would be in that neighborhood for the six gear, does that sound about right? I'll most likely run lipo with modern tires, just ripping around the yard, if that matters.
Also, 1.83, 1.85 or 1.87 internal ratio? I've seen all three listed. I meant to count the teeth myself when I had the trans apart, but it's closed up now and I'm not going back in there until I have to.
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
Re: Gearing suggestion for Reedy Radon 2 19T, six-gear
I've never run lipo batteries, but I'm finding that 3000mah NIMH is a lot of power and run time for a brushed motor. I'm finding that I need to have time limits (which I hate) to avoid overheating brushed motors. I haven't seriously shopped for lipos, so maybe there are some that are brushed motor friendly. What type are you planning to run?
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
This is from the RC10 Classic manual. It even has a 19T listed.
I'm about to put a 19T Radon in a six gear car. I planned on starting with 81/18, 48P gears.
Keep in mind that early RC10 tires are shorter than modern 2.2 tires, changing the effective gearing.
- flatspunout
That would put me at 54/11-12.
Which sounds about right because my smallest current pinion is a 13T. Of course.
- flatspunout
Not sure yet, something that fits without modifying the setup I have now. I have the battery cup almost touching the servo mount and most new lipos are slightly too big in every dimension. I have a Thunder Power 5000 that fits perfect but it is 10 years old at least and was rode hard in 17.5 boosted touring car and mod dirt sprints, now it won't balance and seems like a liability.Frankentruck wrote: ↑Sat Jul 24, 2021 8:02 pm I've never run lipo batteries, but I'm finding that 3000mah NIMH is a lot of power and run time for a brushed motor. I'm finding that I need to have time limits (which I hate) to avoid overheating brushed motors. I haven't seriously shopped for lipos, so maybe there are some that are brushed motor friendly. What type are you planning to run?
- R6cowboy
- Has thanked: 871 times
- Been thanked: 903 times
My Reedy Wolfpack 3300mah 2s Lipo (hard case) is almost the exact same dimensions as my 6 cell Nimh batteries, only difference is the 2s is only 1/8" longer. Thickness and width are the same. Likely the closest 2s dimensions you're going to get to a Nimh battery.flatspunout wrote: ↑Sun Jul 25, 2021 12:11 am Not sure yet, something that fits without modifying the setup I have now. I have the battery cup almost touching the servo mount and most new lipos are slightly too big in every dimension. I have a Thunder Power 5000 that fits perfect but it is 10 years old at least and was rode hard in 17.5 boosted touring car and mod dirt sprints, now it won't balance and seems like a liability.
-Jerry-
- juicedcoupe
You buy lipo stick packs, same dimensions as nimh. They even fit older Tamiya cars.
- 553 Views
Last post by tony6187
- 792 Views
Last post by juicedcoupe
- 2435 Views
Last post by knixdad
- 1052 Views
Last post by i crash cars
- 2164 Views
Last post by teman
- 598 Views
Last post by bully
- 2297 Views
Last post by flustorm99
- 1986 Views
Last post by carloco8
Users browsing this forum: Bing [Bot] and 4 guests
