As the title states, I am looking for a starting point for a 14T double. I'm running an 81T spur and the car will be run a very tight track with one long straight.
Thanks.
14T double, 2.25 Stealth gearing suggestion
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
- bully
- Been thanked: 6 times
Re: 14T double, 2.25 Stealth gearing suggestion
With 81 tooth spur start with 13 or 14 tooth pinion and run for 3 minutes and check temps,if around 55 -60 degrees Celsius go smaller if under 50 degrees Celsius let cool and run full five minutes and check final temps again..
- 1054 Views
Last post by i crash cars
- 1247 Views
Last post by juicedcoupe
- 1106 Views
Last post by DerbyDan
- 2542 Views
Last post by Farabomb
- 984 Views
Last post by aconsola
- 1244 Views
Last post by ca-rj
- 1695 Views
Last post by peetbee
- 763 Views
Last post by toolman72
