I was wondering if anyone has used a Dhawk Metal Transmission case?
How did it turn out, in terms of accuracy?
Was it a good choice of cases?
Ever use a Dhawk Metal Stealth Case?
- Has thanked: 307 times
- Been thanked: 5 times
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: Ever use a Dhawk Metal Stealth Case?
For the shelf it would be fine I guess. Mostly using original stealth cases for my runners...
- Has thanked: 5 times
I recently built one for my DS and it is smooth, I have not run it yet so I can not speak to longevity or wear on parts. I would assume it is not quite as precise as the small batch aluminum cases that have been made.
- Regular Member
I recently purchased the Dhawk metal case to replace the stealth on my Team Car. I was actually looking to just replace the idler gear because it had stripped the teeth on it. As I was looking for the gear, I found Dhawks aluminum case and decided to get it. Question: what bearings go in the case that hold the top shaft? I used the same size bearings that was in the stock stealth and I am getting a lot of axial and radial play in the top shaft. Something is different w/this case and I am not too familiar with the RC10 models after the team car to know what changed. Thanks!
- 879 Views
Last post by XLR8
- 3403 Views
Last post by killswitch
- 1007 Views
Last post by mAdMan
- 3344 Views
Last post by Lowgear
- 2152 Views
Last post by gula
- 3293 Views
- 772 Views
Last post by Dadio
- 3927 Views
Last post by TOLITS
Users browsing this forum: carloco8 and 4 guests
