Just scored a NIP stealth case
General info, Q&A.
gula
Post by gula »
where do I get internals?
I have five terrorists going southeast on Bakalakadaka street.
aeiou
Re: Just scored a NIP stealth case
Post by aeiou »
http://www.towerhobbies.com
They should have everything you need.
gula
Post by gula »
So the gears inside havent changed from the gold pan till now? Maybe I should have ben more specific. The stealth case I just got is white nylon one for a Gold pan chassis.
Bugle
Post by Bugle »
Yeah the gears have changed, just go through the RC10 team car or RC10T manual, get the part numbers for everything, type part numbers into tower and the parts will come up.
You have the option of using a B4 top shaft and slipper if you want to go that way. I don't think you can get original slippers anymore so you'll have to use a B3 slipper if you want to go with the original type.
gula
Post by gula »
this manual you speak of do they have it on here?
gula
Post by gula »
found it, but was not able to find some of the parts
Bugle
Post by Bugle »
The manuals for everything are on the team associated website. What parts couldn't you find?
If you search for 'stealth' on tower pretty much all the parts come up
gula
Post by gula »
the nut that goes into the outdrive, the slipper <-only found one side. Overall I found that it's pretty expensive to put one of those together from scratch. Also couldn't find the felt "washer if you want to call it that.
skunk.werkz
Post by skunk.werkz »
gula
Post by gula »
ahhhh. I also just got a bunch of other parts, and was wondering if they are a stealth parts for the gold pan? No how do I post pics here? Also got some sort of losi truck, it has a white bulkhead, the tranny says: 2.61:1 and is grey, has a pinkish grey motor plate, some nice looking shocks, CVd's that look partial plastic "grey plastic", a retro series horsepower motor by speedworks, what look like lunsfort Ti turnbuckles, a red bellcrank steering with grey alloy cross "thingie" Fiberglass shock towers. Can anyone help identify this?
Chewbacca
Has thanked: 51 times
Been thanked: 108 times
Post by Chewbacca »
Check THESE out so you don't end up with parts for the B4 that won't fit. I would go with the B4 top shaft and slipper though.
*** POWDER - KING ***
Brandon G
Post by Brandon G »
gula wrote:ahhhh. I also just got a bunch of other parts, and was wondering if they are a stealth parts for the gold pan? No how do I post pics here? Also got some sort of losi truck, it has a white bulkhead, the tranny says: 2.61:1 and is grey, has a pinkish grey motor plate, some nice looking shocks, CVd's that look partial plastic "grey plastic", a retro series horsepower motor by speedworks, what look like lunsfort Ti turnbuckles, a red bellcrank steering with grey alloy cross "thingie" Fiberglass shock towers. Can anyone help identify this?
Probably an LXT with the retrofit tranny conversion. What is the chassis made out of?
gula
Post by gula »
looks to be carbon composite. Retrofit tranny conversion, that something good or bad?
gula
Post by gula »
Where can I get the cover for the motor plate "clear lexan dust shield" also will a 6 gear tranny motor plate bolt up to the stealth case? or do I need to get a different one, if so which one would that be? Very RC10 illiterate :roll:
aconsola
Post by aconsola »
ebay for the dust cover. 6gear plare will work but you will need to drill and tap one hole. pretty easy to do: once you mount the plate with the 3 screw holes that do line up already, use the 4th as a drill guide.
