Trx-1 runner
popboy905
Been thanked: 10 times
Trx-1 runner
Post by popboy905 »
Purchase this trx-1 to make a runner a few years back and finally have the time to start cleaning it up to make a runner
RCveteran
Has thanked: 26 times
Been thanked: 200 times
Re: Trx-1 runner
Post by RCveteran »
What are your plans, and you probably already know the front bulkheads are on backwards. TRX1 owners are a small but prestigious and quietly confident bunch :lol:
Lavigna
Has thanked: 1099 times
Been thanked: 1418 times
Re: Trx-1 runner
Post by Lavigna »
That should clean up real well. It may end up being too nice to run. I'll be following along. I'm currently looking for a nice TRX-1 myself.
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Re: Trx-1 runner
Post by adam lancia »
RCveteran wrote: Sat Feb 06, 2021 10:32 pm What are your plans, and you probably already know the front bulkheads are on backwards. TRX1 owners are a small but prestigious and quietly confident bunch :lol:
The previous owner was going for the Masami Worlds Stealth look :mrgreen:
Looks like a great base to start with, I'm sure it'll be a fun runner.
RCveteran
Re: Trx-1 runner
Post by RCveteran »
[/quote]
[/quote]
You are right, we all know the TRX1 was breathing down Masami's neck at the 91 Worlds. So clearly this car was a secret factory attempt to lure Masami over to Traxxas.
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Re: Trx-1 runner
Post by TRX-1-3 »
RCveteran wrote: Sat Feb 06, 2021 10:32 pm What are your plans, and you probably already know the front bulkheads are on backwards.......
A mad attempt to clearance the steering from the inboard upper link mounts. Gets pretty hairy in there. Esp. with the A&L setup.
RCveteran
Re: Trx-1 runner
Post by RCveteran »
TRX-1-3 wrote: Sun Feb 07, 2021 9:28 am
Unlike one of those antique RC10's where the wrong spacer, ball stud, wind direction or ball end ruins everything, miles of clearance here :D
popboy905
Re: Trx-1 runner
Post by popboy905 »
Well I planned on this being a modern runner, but after breaking the car down and cleaning and boiling the plastics, some of the parts are way to brittle. I am going to replace white suspension parts with black parts.
Lucky the car came with a few spares
Has thanked: 268 times
Been thanked: 2094 times
Re: Trx-1 runner
I never boil anything, just soak in fairly hot water.
One of the cheap, mini crock pots works well. No hot spots on the bottom either.
Dadio
Has thanked: 2757 times
Been thanked: 2250 times
Re: Trx-1 runner
Post by Dadio »
it takes hours to rehydrate nylon 8-10 in hot water depending on the thickness of the part , you can do it cold but then its 24 -48 hours .
TRX-1-3
Re: Trx-1 runner
Post by TRX-1-3 »
RCveteran
Re: Trx-1 runner
Post by RCveteran »
Bandit rear arms are the same. You can also use Bandit/Rustler front arms, you'll need to use some spacers on the suspension shafts. Or some have actually taken a bandit front bulkhead and split it down the middle, took a potion of it out to make homemade TRX1 bulkheads with the bandit arm mount size.
https://www.rc10talk.com/viewtopic.php?f=31&t=41796&start=45
Bulkhead mod, done on TRX3, same idea.
https://forums.traxxas.com/showthread.php?9000434-SRT-to-TRX3-TCP-Front-bulkhead-mod-question
popboy905
Re: Trx-1 runner
Post by popboy905 »
Freshing up the transmission with new internals, drag race concepts top shaft with a steel 21t gear to run the ae slipper.
Dyed the yellowing case and bulkhead black.
Re: Trx-1 runner
Ugh sorry to see those brittle pieces.
TRX-1-3
Re: Trx-1 runner
Post by TRX-1-3 »
popboy905 wrote: Wed Feb 10, 2021 6:02 pm Freshing up the transmission with new internals, drag race concepts top shaft....
So there is still a modern aftermarket top shaft available for the slipper conversion aside from the STRC one! Nice nugget of info there. Thanks.
How's the fit on that top shaft? I found the STRC one to be ever-so-slightly wobbly. Even after the precision shimming effort. Didn't seem to be an end-play issue. May have been my bearings though I guess.
Return to “Traxxas Forum”
