2.2" wheels for TRX-1 & TRX-3
- Regular Member
- Has thanked: 4 times
- Been thanked: 4 times
what wheel options have you found that work for a TRX-1 and TRX-3? Do the Traxxas 2474 Bandit wheels work? They look like they would. How about fronts? anyone make a wheel that fits a 10mm bearing that has the right offset?
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2092 times
Re: 2.2" wheels for TRX-1 & TRX-3
Probably these, although you should confirm with them.
https://www.jcracingproducts.co.uk/wheels/traxxas-1/traxxas
Even though they are in the UK, my orders have always arrived surprisingly quick.
Just note that the fronts are the narrow design. You will need matching tiles. Schumacher and Pro-line have a few. JC Racing also has some of their own. I have also used vintage 2.15" tires on them.
Just didn't confuse JC Racing with JConcepts. I see it happen often.
- TRX-1-3
- Has thanked: 2063 times
- Been thanked: 991 times
Can confirm JC Racing wheels for vintage Traxxas do fit.juicedcoupe wrote: ↑Wed Jun 11, 2025 4:55 pm Probably these, although you should confirm with them.
Or you could find some TRA2672 rears 2.2 for TPC/TRX-3. I've ran hexes on the rear before (I believe they were Schmacher pre mounted), never the Bandit wheels though. You could just order a pair of Bandit hex rears and see if they fit, then convert the front to hex using Bandit knuckles and carriers and run the Bandit fronts too. Or if you can find a set of original Bandit wheels, pin drive rears and bearings in wheel front. I guess the mini e Revo wheels are hex and sized at 1/10th 2.2 buggy. Those for the rear? Not sure about the offset though.
- 3296 Views
Last post by TRX-1-3
- 1555 Views
Last post by JK Racing
- 27 Replies
- 4884 Views
Last post by rctenracer
- 1332 Views
Last post by Lonestar
- 2151 Views
Last post by klavy69
- 2321 Views
- 2111 Views
- 3868 Views
Users browsing this forum: Yandex [Bot] and 0 guests
