thrust bearing washer??
Was looking arounnd online this morning and saw this on fleabay. Says it improves the diff and gives it more punch?? Anyone have any idea what that means?
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: thrust bearing washer??
That was what Associated printed bitd, it's just a copy/paste for the sellers. I have no idea why it was said to have more punch, I always figured they changed it due to the cost of the tiny thrust bearing assyThis is the Team Associated Stealth Transmission Thrust Bearing Set.
FEATURES: This new washer type thrust bearing washer replaces the older
ball in cage retainer type style thrust bearing.
Offers improved performance of the clutch giving more punch.
INCLUDES: One 5-40 steel locknut with nylon insert
One brass thrust bearing washer (1/8 id. 5/16 od. 1/16 thick)
Two steel polished thin washers that sandwich thrust bearing washer
Instruction sheet
COMMENTS: This is installed on the main spur gear shaft and is sandwiched
between the torque control spring and 3/16 x5/16 bearing/bushing.
The thrust bearing no longer has balls inside it is solid.
AXY 6/21/94
Associated
Part ASC6594
I read the same thing. Seemed a little confusing .. just wondering how it would effect the diff when trying to set it?
It doesn't effect the diff at all, just the slipper. Bitd I remember them switching to it but never saw a difference. They also lost the slipper bearing and went to a bushing at the same time. Always seemed like cost cutting to me.
My bad. I wrote diff but was thinking slipper. Ill prob grab a few az the old slipper thrust bearing is hard to find. This way ill always have something to use..
- 1011 Views
Last post by Tamlok
- 1223 Views
Last post by superfly
- 887 Views
Last post by aconsola
- 1969 Views
Last post by adam lancia
- 895 Views
Last post by sandkil
- 1935 Views
Last post by kaszal
- 428 Views
Last post by Bongo Fury
- 992 Views
Last post by CTYankee
Users browsing this forum: Google Adsense [Bot] and 4 guests
