Trans gears
bandit2026
Trans gears
Post by bandit2026 »
One of the fast guys at my local dirt oval says removing a set of gears from the dif improves speed, What say you??
RS Chris
Been thanked: 19 times
Re: Trans gears
Post by RS Chris »
What kind of car? I assume you mean a gear diff? Did he use a left-handed wrench to do this also?
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Re: Trans gears
Post by TRX-1-3 »
I might be a couple short of a full gearset, but if there are 4 bevel or "spider" gears or whatever we're calling them..if you removed two opposite each other, there would be less rotating mass and maybe enough strength in those remaining two gears to handle it all?
This dude might be yanking your chain though.
I should not have posted this because after I read it, I sound like an idiot. I bet LTO_Dave would know a real answer.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Trans gears
Post by Lonestar »
"faster" means different things to different people.
In 2wd offroad it's sometimes done these days to increase the amount of oil in the diff, which theoretically gives a more consistent feel throughout the run. When I tried it I couldn't feel anything different :lol:
Has thanked: 1735 times
Been thanked: 1145 times
Re: Trans gears
I hear that 10Talk member @THEYTOOKMYTHUMB is an expert on trans gear.... he'd be the guy to ask.
bandit2026
Re: Trans gears
Thanks to those who replied. Only thing I could figure less rotating mass down straight and less friction in turns.
Re: Trans gears
yeah, it would possibly be more efficient if the diff assembly is stable with just two planet gears instead of 4. less chance for gear mesh to create friction, but a too loose diff is also an opportunity to lose traction. one wheel peel.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarDotNetDotCom.org [Bot], No User AvatarGoogle Adsense [Bot] and 6 guests
