Electric Stealth trans with GT gears?
TitaniumXRC
Post by TitaniumXRC »
I ended up with a pile of RC10T parts, and when I combined them with the parts I already have I had almost enough for another truck. I decided to piece it together, but I'm missing a few parts, and I ended up with a RC10GT trans. My question is can I buy an electric trans, and use the gears from the GT trans?
Been thanked: 3917 times
Re: Electric Stealth trans with GT gears?
Slipper, upper gear, and idler will transfer to a 2.65 case, but the 2.65 outdrives and case are currently expensive. When associated re-releases the stealth you should be good to go. A T2 case will fit all the GT components but doesn't bolt up to the older truck directly.
Return to “RC10 Truck Forum”
