Are the tubs ment to be flat?
graemevw
Has thanked: 7 times
Been thanked: 17 times
Post by graemevw »
Just cleaned up my tub and noticed its not flat.
Took a bad pic against the wall to try and show, forgive the state of my work table!!
It doesnt seem to have ever had any impact.
I appreciate even if they are ment to be flat, its a stamped product and so wont be perfect, but this is bowed and has a slight kick up at the front.
Thanks.
RC10resto
Has thanked: 1488 times
Been thanked: 550 times
Re: Are the tubs ment to be flat?
Post by RC10resto »
Yes, it should be flat.
Many are bent :wink:
graemevw
Post by graemevw »
RC10resto wrote: Wed Jan 22, 2020 12:47 pm Yes, it should be flat.
Tm not surprised. Its no problem, ill straighten it, just didnt want to do that then find out it should be like it is.
Been thanked: 3919 times
It was pretty common when racing to slap it over your knee and tweak it back flat again. Tilt it 45* and hold it to the edge of a table, keep bending and when it’s flat you are ready for your next race.
These also help :wink:
graemevw
Post by graemevw »
I bet they do!
RC10resto
Post by RC10resto »
I have not had the best luck with the over the knee approach.
I mount the chassis nose to a wood structure and apply smooth even pressure.
graemevw
Post by graemevw »
Ill probably do similar but ill clamp in in the vice, in some wood.
orangemazda
Has thanked: 14 times
Been thanked: 60 times
Post by orangemazda »
That’s exactly how I do it.
RC10resto wrote: Wed Jan 22, 2020 3:29 pm I have not had the best luck with the over the knee approach.
aakoskin
Been thanked: 7 times
Post by aakoskin »
I have checked two new/unbuilt World's re-re kits, and both have tubs that are slightly bent at the front. They are pretty much the same as on my 1986 Edinger (a car with a racing history), which would suggest it's kind of normal shape.
Wouldn't frequent straightening weaken the metal and make it prone to bend even more?
graemevw
Post by graemevw »
I dont have much experience of these cars, but my guess is they were probably never dead flat. They will always spring a little out of the press. I guess some are better than others.
Ive straightened this one now though, just clamped in the vice between wood and pulled/pushed. It wasnt bent in one place, the whole pan was sort of cupped a little. Its pretty flat now though, maybe 1/32 of light under a straight edge at each end.
Part of the issue is that you see some flex as the sides of the tub move in and out. You need to rigidly fix the sides as well when reshaping the chassis. Or just get it close and not worry about it.
graemevw
Post by graemevw »
jwscab wrote: Thu Jan 23, 2020 9:39 am part of the issue is that you see some flex as the sides of the tub move in and out. you need to rigidly fix the sides as well when reshaping the chassis. Or just get it close and not worry about it.
I went for the second option 🙂
