Moderators: scr8p , klavy69
Tobyone
Posts: 5 Joined: Thu Jun 21, 2018 4:06 pm
Post
by Tobyone » Fri Jun 22, 2018 1:19 am
Hi,
I decided to resurrect my old zxr mk2. When I switch it on the light on the speed controller is solid red. The servo works fine but the motor respond to the transmitter.
The manual says to move the receiver cable to another socket. When I try this the motor spins up fine with the left/right on the transmitter. When I move the receiver cable back to battery, the motor starts and just stays on. Where is the problem here? Thanks
Posts: 12336 Joined: Sun Apr 29, 2012 10:31 pm
Has thanked: 1129 times
Been thanked: 3919 times
Post
by GoMachV » Fri Jun 22, 2018 1:26 am
Esc needs to plug into channel 2 not battery. Once in channel 2, thats when you will need to make your adjustments.
RC10th
Posts: 4761 Joined: Sat Feb 16, 2013 9:51 am
Has thanked: 52 times
Been thanked: 1548 times
Post
by RC10th » Fri Jun 22, 2018 2:05 am
If you plug the steering servo into channel 2 does it work with the trigger?
But yes,
Steering Ch. 1
Throttle Ch. 2
Tobyone
Post
by Tobyone » Fri Jun 22, 2018 12:45 pm
Hey, yeah if I plug it into channel 2 the motor spins up and is controllable, but only backward! Pushing the receiver control forward only seems to brake.
T.
Post
by GoMachV » Fri Jun 22, 2018 12:49 pm
You need to flip the servo reversing switch on the transmitter. Then you will also need to flip the motor wires if it runs in reverse (make sure if you have a diode attached it is properly oriented!!!). That speed control doesn’t have reverse, only forward and brake.
Tobyone
Post
by Tobyone » Fri Jun 22, 2018 1:40 pm
Yeah it all looks like it's wired correctly. It's soldered and hasn't been changed since I last used it.... Is it possible something else is going on?
Post
by GoMachV » Fri Jun 22, 2018 2:09 pm
The only way the motor can spin backwards is if you removed and spun the end bell 180 degrees, or if you changed its direction mechanically- like in a vehicle with bevel gear diff installed backwards or a mid motor conversion
Tobyone
Post
by Tobyone » Fri Jun 22, 2018 4:33 pm
How do I upload a picture?
RC10th
Post
by RC10th » Fri Jun 22, 2018 11:21 pm
I'm thinking the servo reversing switch has been flipped on the transmitter like mentioned earlier.
Tobyone
Post
by Tobyone » Sat Jun 23, 2018 5:40 am
Hi yeah the servo switch does mean that pushing the control forward accelerates...but backwards. I took a pic of the motor. how can i upload it?
RC10th
Post
by RC10th » Sat Jun 23, 2018 9:49 am
Yes, servo reversing switch "reverses" the function. So try flicking the Ch. 2 switch on the remote.
If the trigger was 50/50 then reversing then the esc would operate normally just backwards, a 70/30 trigger would run on like you described.
Last post by 8rad
Wed Jun 08, 2011 12:50 pm
Last post by juicedcoupe
Fri Sep 24, 2021 4:16 pm
Last post by morrisey0
Tue Mar 14, 2023 10:45 am
Fri Apr 06, 2012 3:11 pm
Last post by 8rad
Mon May 07, 2012 11:01 am
Last post by RC10 Junkie
Fri May 11, 2012 3:38 pm
Last post by Andybellus
Mon Jun 03, 2024 10:56 pm
Last post by Lonestar
Mon Jun 17, 2013 4:43 am
Users browsing this forum: Seznam [Bot] and 5 guests
