New Composite RC10 buggy.....
Md_RC10
Post by Md_RC10 »
I found what I believe is some sort of Composite RC10 buggy on Ebay.
Anyways I purchased this buggy and I will begin trying redo a couple things to get it up and running again.
I did notice during my inspection that there is a thin metal plate sitting between the chassis and the Stealth transmission.
I'm guessing that this is sort of BS modification.
Erik
White Hall, Md.
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Re: New Composite RC10 buggy.....
Post by vintage AE »
I bet the metal plate is the "template" that people used to drill hole from a 6 gear tranny to a stealth tranny. For some reason, who ever driller the new holes didn't remove the plate and just screwed the trans on top of it. I would remover the plate and screw the transmission back down.
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Should be a good project!
Md_RC10
Post by Md_RC10 »
DaveM wrote: Sun Mar 11, 2018 9:38 pm Should be a good project!
Thanks DaveM....
I pulled some stuff off the chassis, including the transmission.
Trying to get an idea of what I want to do with the chassis, pretty sure that I want to get rid of all the dyed parts at this time.
I need to start a parts list.....
Unknown on brand of shocks I have here, I'm definitely keeping the Andy's Arms front and rear...
Erik
White Hall, Md.
DaveM
Post by DaveM »
Hi,
I am doing a similar rebuild of a graphite buggy, here is a link it may give you some ideas,
https://www.rc10talk.com/viewtopic.php?f=35&t=40536
It is what someone called a zebra buggy, a mix of black and white parts.
I would try to keep as much as original as possible.
Maybe change out the front and rear suspension mounts, front caster blocks and rear hubs to white,
and re-dye the rear bulkhead black.
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
