Lazer ZX adjustable lipo tray
lin6499
Post by lin6499 »
This lipo tray can be adjusted forward/backward.
I'm still working on it because it is not sturdy enough.
rccars4sal
Re: Lazer ZX adjustable lipo tray
Post by rccars4sal »
Nice idea for the shorty. Im not sold on adding more front belt tension though.
Welshy40
Post by Welshy40 »
Now you have my attention, i like the tensioner idea and the lipoholder which I would like have when finished.
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
rccars4sal
May be its because I dont run any lazers any more, but all my built lazers have pretty tight front belts. I dont think they could even use a tensioner. On the other hand, a lazer alpha I had was one car that had very loose front belt. All my current lazers are very tight, and draggy because of it.
Welshy40
Post by Welshy40 »
My belts megga loose, in 89 I found that it was a lap more efficient with a softer belt compared to a taught one. Ok batteries have changed since 1400s but the car is stupidly faster without a taught belt now, I use a 4.5 in mine now and easily beats the cars of nowadays. Mind you that was before I invented the carbon fibre tub chassis and then it got much looser and faster as well as more efficient.
This lipo tray is a clever idea, it inivitve design goes beyond the normal and opens the door to other setup ideas, this idea would be a superb idea on clay and low grip plus think it could work on astro high grip as well. The belt tensioner on the middle top deck mount isnt doing much as the belts movement under full throttle is ridiculous and this canny idea solves the damage to the battery casing and the belt. Its nice to see someone else has a passion for this car and has the idea to put it into the real world. Well done, this is stunning and I dont say it often but simplicity it looks but it definately wasnt to design.
Sponser links below
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
rccars4sal wrote: Sun Aug 06, 2017 11:54 pm May be its because I dont run any lazers any more, but all my built lazers have pretty tight front belts. I dont think they could even use a tensioner. On the other hand, a lazer alpha I had was one car that had very loose front belt. All my current lazers are very tight, and draggy because of it.
The Lazer Alpha front belt is very loose due to a design error involving the motor mount and chassis - basically the chassis flexes so much right in front of the motor mount, also due to the absence of a brace on the left side, that the belt slacks. Replace the stock motor mount by a regular Lazer mount and add the left side brace, and the problem disappears.
rccars4sal
I def like the idea of a shorty solution for the lazer. It would be easy enough to make the front end about 1 or 2 mm adjustable to accommodate the tensioner.
lin6499
Post by lin6499 »
I'm no native speaker, so I try not to be too talktive.
Thanks for your comments above, guys.
Second thoughts. Two options of battery position.
How it works.
I bought the Lazer ZX about one month ago, it didn't come with the gear cover, I decided to make one.
Waz
Post by Waz »
Keen to see the printed gear cover :D
lin6499
Post by lin6499 »
I put a little thought into this, a bit difficult to print though.
lin6499
Post by lin6499 »
OK. Adjustable & quick release lipo holder, done.
foward.
backward.
front belt.
Delorean
Been thanked: 14 times
Post by Delorean »
This is awesome!! are you planning on putting it up on shapeways?
Cheers
lin6499
Post by lin6499 »
Delorean wrote: Mon Oct 02, 2017 10:11 pm This is awesome!! are you planning on putting it up on shapeways?
Cheers
Thanks, but I'm afraid not. It requires too many parts.
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarDotNetDotCom.org [Bot] and 2 guests
