ESC Tray
ESC Tray
Does anyone make an ESC tray that mounts to the rear shock tower and allows the esc to sit upright as seen in many photos posted? Have not had any luck finding one.
Also, is there an aftermarket or another manufacturer's battery tray that will screw right into the chassis without serious modifications?
Re: ESC Tray
I used to use the two way servo tape back in the day to mount the ESC to the rear shock tower and maybe a zip tie for added holding power as did most people.
I'm not sure what people do now.
Lynn
Lynn
Re: ESC Tray
If you countersink the holes on the shock tower and use flathead screws the ESC will mount pretty well using servo tape.
Holeshot or somebody made a graphite ESC shelf, but it was just a section of carbon fiber angle cut to 1.5" wide or something. I have it, it works ok, but it's nothing special. You could do the same thing with a piece of aluminum angle stock from the hardware store cut down to fit. Or just some aluminum or Kydex plastic or something semi-rigid and bend it to a 90 degree angle.
I remember this from the JR-XT track report in RCCA, I want to give it a try and see how it works.
- Attachments
- ESC shelf 2.jpg (52.57 KiB) Viewed 876 times
Re: ESC Tray
Holeshot racing products made one out of carbon fiber real nice, way back in 92 can be seen in the Dec issue in the scan section. I managed to snag a few way back in the days. I used a few for my helo's as a switch and charging jack plate and one can be seen on my Duratrax conversion kit.
- 748 Views
Last post by knixdad
- 1693 Views
Last post by bully
- 602 Views
Last post by caesar
- 1926 Views
Last post by Pattypassat
- 3686 Views
Last post by AustinZ
- 2272 Views
Last post by lin6499
- 815 Views
Last post by splaice
- 1749 Views
Last post by mrlexan
