Custom Works Adjustable Arms
- Johnboy72
Anyone know what buggy will fit the Custom Work Adjustable arms? I would assume the B3. Just wondering if there is a set that could be modified for an RC10.
- Been thanked: 4 times
Re: Custom Works Adjustable Arms
As far as I know they only make adjustable arms for trucks. I don't think they make a narrower set for cars. I'm not 100% certain though.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Fred, I think you might be talking about the Dynotech arms? CW makes arms for their oval cars with adjustable rear toe and I think Johnboy is right that they are B3 length (plus a wider version).
If they're too wide maybe you could narrow up the RC10 rear end with RPM Worlds arm mounts?
Yeah I'm talking about the adjustable toe CW arms. I'm just not sure if they only make them for trucks or also buggies. Since so much of their car is B3 based, they've probably got something that'll work.
- Phin
Googled it and CW does make SC10 arms so my mistake.
I believe John is talking about the Intimidator, Dominator, & Enforcer arms which come in standard and wide widths.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZJW&P=7
http://www3.towerhobbies.com/cgi-bin/WTI0001P?I=LXDZJX&P=8#
Tower lists the unadjustable wide car arms as 85mm long and B3 arms at 80mm.
- Johnboy72
Only reason I'm asking is one, I know some on here run modern dirt oval and two, I have some random parts here and there. So if I can confirm (probably have to call CW), I can order the right arms (they are making them for more platforms from what I've seen) and start modifying. I just think it would be cool to have that much technology in our RC10s on the track.
Im interested in adjustable toe arms for my RC10 widened out for B4 wheels!
3 FOREVER
The problem with the CW arms is that the swivel point is too far inward which results in a wheelbase change with the change in toe.
- 686 Views
Last post by THEYTOOKMYTHUMB
- 1838 Views
- 2367 Views
Last post by nikos2002
- 2156 Views
Last post by Mr. ED
- 2024 Views
Last post by dldiaz
- 3312 Views
- 1030 Views
Last post by mytimac
- 38 Replies
- 7332 Views
Last post by dillonhoffman
Users browsing this forum: Semrush [Bot] and 7 guests
