Custom nose tubes
Custom nose tubes
Given the rarity of the Truck nose tubes these days, has anyone fabricated their own?
Is this the correct size if one were to tackle that project? I assume the screw holes need to be tapped to a certain thread as well.
3/16" OD
https://www.grainger.com/product/48KU61&AL!2966!3!50916752157!!!g!109232497797!?gclid=EAIaIQobChMI5un3sdaV1QIVDHd-Ch088wLgEAQYAiABEgImzPD_BwE&cm_mmc=PPC:+Google+PLA?campaignid=175662597&s_kwcid=AL!2966!3!50916752157!!!!109232497797!&ef_id=WCnIegAAAW5l7zxa:20170719153654:s
3/16" OD
- NomadRacer
- Has thanked: 81 times
- Been thanked: 79 times
Re: Custom nose tubes
Sorry mate, I don't see that tubing working for you. The optimal size hole for taping 4-40 threads is .0876" (#43 drill size). The tube in the link has an inside dia. of .177" which is to large.
Bum on Direct Deposit
Ah you're right, I was looking at a thread for RC10 wing tubes and grabbed up the wrong dimensions. I will get the calipers out and get the correct dimensions.
- Been thanked: 498 times
if you don't have a lathe or suitable method for center drilling aluminum rod, this is what you want:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDXYH&P=7
it's sold in 1 ft lengths, and has an ID suitable for #4 tap. I usually buy a handful and make my own nose tubes and wing tubes.
If I need something beyond that, I buy 3/16" rod from mcmcaster-carr and roll my own.
BTW, this is really the cheapest and quickest option, believe me I've looked. They've made it tougher lately as you used to be able to buy 10 or 12 in a box, but now it's only available carded.
Excellent!jwscab wrote: ↑Wed Jul 19, 2017 12:25 pm if you don't have a lathe or suitable method for center drilling aluminum rod, this is what you want:
- Has thanked: 33 times
- Been thanked: 1179 times
- RC10th
- Has thanked: 50 times
- Been thanked: 1490 times
Cut down buggy tubes, I screwed a truck tube to the buggy tube for a template, clamped in a drill press vise and drilled the hole, then cut to size.
- 1496 Views
Last post by justinspeed79
- 911 Views
Last post by KidAgain
- 1068 Views
Last post by Lonestar
- 1545 Views
Last post by marlo
- 1110 Views
Last post by SteveK
- 7890 Views
Last post by mk-Zero
- 1059 Views
Last post by rctenracer
- 834 Views
Last post by JosephS
