McMaster Aluminum tube Replacement for Wing/Nose Tubes
- mikedealer
it was posted somewhere a while ago.. but i lost track..
does anyone have the part number from mcmcaster for the aluminum tube that can be cut and made to replace the wing tubes on rc10s?
i can probably find it myself with a caliper but im lazy and my caliper's batteries are dead, and radioshack was out lol.
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: McMaster Aluminum tube Replacement for Wing/Nose Tubes
i don't have a part number for you but iirc the tubes are 3/16 od with a 1/16 id and a 1/16 wall.
- mikedealer
thanks, from what i can see only aluminum in that size is 3003 aluminum, which i guess is it..
part 7237K16
everything else mininum outside diam is 1/4"
isnt that really crappy aluminum? that cant even be anodized right can it?
part 7237K16
probably about the best you will be able to find:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS020&P=M
I have the K&S stuff, use it for links, chassis crossmembers, lots of stuff. Not sure how soft it is though.
it says its 6061 T6, so about the strongest you'll get commercially.
I'm sure this is pretty much what the wing tubes are, as well as the nose brace tubes.
- LowClassCC
just looked that one up and that's the thin wall stuff i wouldn't go with it.mikedealer wrote:thanks, from what i can see only aluminum in that size is 3003 aluminum, which i guess is it..
part 7237K16
now for the k&s stuff on tower. that is more like it. i added it to my tower wishlist.
- Been thanked: 81 times
The k&S tubing is the thick wall tubing. I have used it in the past for some resto porjects. Just cut to length and tap .
- 1551 Views
Last post by justinspeed79
- 1101 Views
Last post by Lonestar
- 1809 Views
Last post by RC10th
- 1080 Views
Last post by KidAgain
- 1586 Views
Last post by marlo
- 1162 Views
Last post by SteveK
- 8226 Views
Last post by mk-Zero
- 919 Views
Last post by JosephS
Users browsing this forum: Google [Bot] and 5 guests
