Why are the old RC10T 3 piece wheels so rare?
It seems like the old 3 piece RC10T wheels were pretty solid, and the feature of not having to glue them would be desirable, why are they so rare now? Seems like ebay searching only turns up a few sets that are pretty expensive. Oddly, front 3 piece wheels are easy to find. Why did associated move away from this design in later models?
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: Why are the old RC10T 3 piece wheels so rare?
I assume they molded the rims in quantities, ie 10,000. Rear ones have all sold out but there is still an abundance of fronts left.
Unfortunately most modern tires don't fit the 3 piece wheels due to internal sidewall webbing.
Are these 1 piece replacements correct for the 1/4inch old style roll pin axles on the 10T?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=003179677&I=LX2948&P=K
- RC10th
Yes, those are correct for the 1/4" axles.
I've given up on the three piece wheels since they don't fit a modern tire. They're also super heavy compared to the solid wheels. They still make the 1/4" solid wheels and I found some for $7.99 a set and glued on modern turf tires. The vintage tires didn't work at all on the turf.
Speaking of tires, comparing my old stock tires and 90's era proline's to some new proline trenchers I picked up for bashing, what the hell happened to tire construction? My old tires are real rubber. These new tires with foam feel like a pair of latex gloves! Do they even hold up? What's this nonsense about having to put freaking gorilla tape on the insides?blk05wrx wrote: ↑Thu May 04, 2017 10:39 pm I've given up on the three piece wheels since they don't fit a modern tire. They're also super heavy compared to the solid wheels. They still make the 1/4" solid wheels and I found some for $7.99 a set and glued on modern turf tires. The vintage tires didn't work at all on the turf.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
its all about traction anymore. You want a soft tire for a hard track and days of soft loamy tracks are mostly just memories anymore. These days tracks are so hard and tires are so soft that they balloon so badly they pull off the rims with the high powered brushless systems and the gorilla tape on the inside of the tires helps keep the tires from ballooning so bad.
I assume with old brushed motors, even modified ones, that ballooning/expansion is not a concern with modern tires, is that correct?
- klavy69
- Moderator
Correct. Some will but most won't balloon near like a nice soft newer tire...
I have my new one piece wheels that fit great but have an interesting issue. My 11/32nds socket won't tighten the rear wheel nuts (asc6296) quite tight enough on account of the angle of the "cone" shape of the wheel and the small width of the nut. The old 3 piece rear wheels have more clearance to allow the socket to fit deeper into the wheel hub area if that makes sense. I wonder if I need a smaller diameter RC wheel nut wrench instead of the regular socket for these wheel nuts.
I had this same issue and just hit my wrench with a grinder/dremel a little bit to make it a little thinner.EMC wrote: ↑Mon May 08, 2017 11:28 pm I have my new one piece wheels that fit great but have an interesting issue. My 11/32nds socket won't tighten the rear wheel nuts (asc6296) quite tight enough on account of the angle of the "cone" shape of the wheel and the small width of the nut. The old 3 piece rear wheels have more clearance to allow the socket to fit deeper into the wheel hub area if that makes sense. I wonder if I need a smaller diameter RC wheel nut wrench instead of the regular socket for these wheel nuts.
Good tip, thanks!blk05wrx wrote: ↑Wed May 10, 2017 2:34 pmI had this same issue and just hit my wrench with a grinder/dremel a little bit to make it a little thinner.EMC wrote: ↑Mon May 08, 2017 11:28 pm I have my new one piece wheels that fit great but have an interesting issue. My 11/32nds socket won't tighten the rear wheel nuts (asc6296) quite tight enough on account of the angle of the "cone" shape of the wheel and the small width of the nut. The old 3 piece rear wheels have more clearance to allow the socket to fit deeper into the wheel hub area if that makes sense. I wonder if I need a smaller diameter RC wheel nut wrench instead of the regular socket for these wheel nuts.
- 1019 Views
- 941 Views
Last post by RogueIV
- 994 Views
Last post by MotoObscura
- 557 Views
Last post by SnoopMaxx
- 1986 Views
Last post by JosephS
- 1383 Views
Last post by blown5.0
- 954 Views
Last post by romulus22
- 539 Views
Users browsing this forum: No registered users and 17 guests
