rc10t 3 piece wheels
I just had a quick question about the 3 piece wheels that came on the rc10t. Are they 2.2 and are you able to put newer type of tires on those rims.
I want to keep the vintage look to my rc10t but dont want to use old tires. i would rather use newer proline rubber.
Thanks.
Thanks.
Hi.
- Has thanked: 7 times
- Been thanked: 42 times
Re: rc10t 3 piece wheels
Yes and yes. You just need to be cautious about how much power you put through the wheels. I'm not sure how well the 3 piece wheels will hold up if you're planning on going LiPo/brushless. Maybe someone else here has tried and could give some input...?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
I haven't tried but I don't think they'll suffer that much from power, not any more than the 1/16th roll pin or so that's driving them . However, tires aren't glued in there, so this could be an issue at some point.adam lancia wrote:Yes and yes. You just need to be cautious about how much power you put through the wheels. I'm not sure how well the 3 piece wheels will hold up if you're planning on going LiPo/brushless. Maybe someone else here has tried and could give some input...?
Best,
Paul
alright thanks. i might just go for the one piece wheels then. i was thinking about put a lot of power in the truck. It was going to be built as a everything car.
Hi.
- Lonestar
I must be missing sthingNorman wrote: i might just go for the one piece wheels then.
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
I had trouble with the current tires on the 3 piece rims because of the foams getting in the way of the seating of the bead no matter what I did, so they really likes spitting tbd tires off!
- 2431 Views
Last post by EMC
- 934 Views
Last post by RogueIV
- 1979 Views
Last post by JosephS
- 556 Views
Last post by SnoopMaxx
- 994 Views
Last post by MotoObscura
- 539 Views
- 954 Views
Last post by romulus22
- 1370 Views
Last post by blown5.0
