Older ESC's and LIPO's?
- nmsuman
- Regular Member
So next topic for the day as a newb.
Older ESC's. So back in the day when I saved my allowance, I purchased an old NOVAK ROOSTER ESC http://teamnovak.com/products/esc/rooster/index.html
Question is, since LIPO power wasn't available back then, would a 2S Lipo kill this thing?
In the Shop: Team Associate RC10T ~'93
On the Road: Axial SCX10 Dodge Power Wagon 2014
Retired/Missing: Nikko Turbo Aero, Tamiya Grasshopper
- bully
- Been thanked: 6 times
Re: Older ESC's and LIPO's?
No as long as you stay under the max voltage it won't be a problem.. If running for full pack you either have to have experience at how lipos dump or buy a voltage alarm type thing.. Just follow the basice lipo rules as you would normally.. If your not that confident definitely get a low voltage alarm...
- abailey21
Bully is right, get a low voltage alarm.
If you know the battery, know the system and know exactly how long you can run you don't technically need one. If you answered no or maybe to any of that, then get an alarm
one other item: lipo's will maintain a high voltage until it dumps. they will also have 2-5 times the capacity of the nicd cells the esc was designed to run with. This means you will have a lot of power to dissipate for 2-5 times longer. Always run it for 5 minutes or so and then check the heat sink temps. if it's too hot to touch, let it cool before proceeding.
while most of the esc's you find have a thermal shut down, it's still not a good idea to keep hitting it constantly.
- nmsuman
- Regular Member
Good information to have.
I know the ESC was able to run a 7 cell hump pack. So 7.2v that means just stay at a 2s Lipo. It's that 0.2v overage going to be an issue?
The voltage alarms I have from flying. So putting on in the truck won't be an issue. Just increases the overall safety.
I have toyed with adding a fan. Even when running the 6 cell Night packs.
I am really excited to get this whole thing back together to see how it all works.
- bully
7 cell is 8.4v so no problem there mate.. Yeah like others mentioned keep an eye on temps of both the esc and motor.. Have fun mate
- nmsuman
- Regular Member
Sorry for the late follow-up. Work is getting in the way of free-time. I think I will start off with 2S to test how the now "old" ESC handles it. As I get comfortable with it, I may ramp up as I see temps stay constant.
Hopefully I get through this before the weather turns to crap here. Already headed in that direction.
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
As long as your ESC is in good shape, it will be fine with a 2s lipo. I run a 2s lipo on a Rooster, Dually, T4, 410M1c and a Duster with no issues. As mentioned above, heat and battery dump should be the only concerns. Have fun!
Matt
- 1721 Views
Last post by REMJ666
- 1980 Views
Last post by tamiya_d1_junky
- 2014 Views
Last post by slotcarrod
- 889 Views
Last post by YakkityYak
- 1644 Views
Last post by THEYTOOKMYTHUMB
- 2340 Views
Last post by RC10th
- 1086 Views
Last post by RCveteran
- 962 Views
Last post by uniquenamehere
