ESC to work with my older fuaba receiver
Does Duratrax or someone make a new ESC with the fitting that will work with my older futaba FP-R112JE receiver ??? Here is a pic of what it looks like...
- Attachments
- SAM_1025 (500x375).jpg (152.13 KiB) Viewed 1707 times
- SAM_1024 (500x375).jpg (173.64 KiB) Viewed 1707 times
Re: ESC to work with my older fuaba receiver
Another post with no reply...Thanks Yall...
- Charlie don't surf
- Has thanked: 357 times
- Been thanked: 470 times
That fitting is irrelevant as you can change the plastic plug for the specific reciever, as long as the wires are in the correct place its good to go.
- Has thanked: 1129 times
- Been thanked: 3919 times
yes, that is the futaba "j" connector and is still widely available and is futabas only 3 pin connector currently available (that I can think of)
the previous connector, the "g" connector, has male pins
sorry it took 4 whole hours to reply, I was sleeping
Thanks for the reply...All is forgiven...
- slotcarrod
- Been thanked: 45 times
Any modern esc with a JR/Hitec Airtronics plug, will plug right in, just make sure the wire is in the same location as original! In other words, don't plug it in backwards, as it's not keyed!
Rod Littau
I'm partial to the Novak speed controls. You can pick them up used for around $20. The T4 is good down to around 15 turns (the older controls were not rated by turns). The Novak Cyclone is a great no limit control for around the same money. For some reason the bulkier no limit Novak Roosters go for more than twice that amount. No, I don't work for Novak.
Thanks for the response...
- 5701 Views
Last post by R6cowboy
- 2454 Views
Last post by matt1ptkn
- 1979 Views
Last post by tamiya_d1_junky
- 2337 Views
Last post by JosephS
- 168 Views
Last post by morrisey0
- 793 Views
Last post by Bimdapogs
- 1466 Views
Last post by DennisM
- 2738 Views
Last post by Lonestar
