Does SC10 Steering parts fit RC10B1 A Arm?
Forum rules
- Regular Member
I found a kit online to convert the SC10 2WD to all four wheels to 12mm Hex. So I can use any modern wheels, but I don't want to spend $35 if they don't fit. Please help.
- bully
- Been thanked: 6 times
Re: Does SC10 Steering parts fit RC10B1 A Arm?
If your asking if you can use them with RC10 arms, you can but you have to drill out the hinge pin hole to 1/8"..
- Regular Member
Thank you. Now I just have to order the kit, and try it.
- Regular Member
Incase some else is wondering here is a site that sells the parts.
http://www.avidrc.com/product/5/accessories/494/SC10-Clamping-12mm-Hex-Conversion-AV1001-CONV-accessories.html
- bully
Mate you still need to use the sc10 caster block with that steering block.. And you can do it for much cheaper with sc10rs parts from team associated...
- 1258 Views
Last post by cautiousone
- 507 Views
Last post by RCveteran
- 439 Views
Last post by Dangeruss
- 860 Views
Last post by longboardnj
- 535 Views
Last post by mAdMan
- 19 Replies
- 7950 Views
Last post by covell2
- 987 Views
- 1151 Views
Last post by broodenburg
