Modernizing the RC10 hubs with SC10, B4, and other parts
General info, Q&A.
shoman24v
Post by shoman24v »
Has anyone here performed this modification to the RC10? If so, can you post links to the parts and prices?
I think this would be a great way for those who want to keep the RC10 look but update some of the parts. I plan on doing this soon to my World's car, but I don't want to buy incorrect parts since this conversion will not be cheap. So far, I calculated +$130.
Pictures taken from Facebook.
| XXT | XXT 'CR' Graphite Plus | RC10T | RC10T2 | RC10 World's Re-release | HPI Blitz ESE | Schumacher SV2 |
Re: Modernizing the RC10 hubs with SC10, B4, and other parts
you don't need the fancy rear hubs or hexes, unless you wanted them. the plastic parts would be perfectly fine. that should knock the cost down a little.
you should be able to find the front and rear hubs as take off parts pretty easily on ebay. for that setup, I believe the CVDs are B44 rears. these modifications are part of the 'whats old is new' line of cars that people have been building for a couple years now. plenty of search material for you to dig through.
bearings from avid are $1.00 each. Jconcepts wheels are cheap for a pack of 4 rears or fronts, so you end up with a spare set. I'd say you might be able to do that conversion, including wheels and tires for less than $100 with some smart shopping.
shoman24v
Post by shoman24v »
I assume I will need the 0 degree rear hub carriers?
I'll probably get the more fancy stuff, just will make the car look a bit cooler.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
I wonder what drive shafts they went with? I found the B44's to be too long.
shoman24v
Post by shoman24v »
B44 rear CVAs. I just wanna lay down the parts for those who want to do this.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Parts I see:
AE rear CVA, B44 - 9756
AE rear hub (alloy), 9864 (0 degree), 9865 (.5 degree), 9866 (1 degree) *
AE rear hub tower (C? in CF), 9873
AE B4 front carriers (20 degree is my suggestion), 6214 *&**
AE B4.2 front knuckle, 9880
AE B4.2 kingpin, 9622 (kit, more than you need)
Unknown parts:
Front & rear alloy hex adaptors
Front axle (B4, T4, SC10?)
* drilled for 1/8" hinge pin
** 20 degree will give the RC10 25 degrees of caster (preferred)
shoman24v
Post by shoman24v »
Here's the list I've compiled. I can't seem to figure out the front stuff needed. Not what most may what to do, but you get the idea.
Rear end parts:
#9864 - Aluminum Hub Set $30.99
http://www.amain.com/product_info.php/cPath/1_25_1450_369/products_id/177911/n/Team-Associated-Factory-Team-0-Aluminum-Hub-Set-2
#9873 - Carbon Hub Fiber C Tower $11.75
http://www.amain.com/product_info.php/cPath/1_25_1450_369/products_id/202594/n/Team-Associated-Factory-Team-Aluminum-Hub-Carbon-Fiber-C-Tower-Set-2
#9580 - B44 Rear CVA Set $26.49
http://www.amain.com/product_info.php/cPath/1_25_1450_701/products_id/18345/n/Team-Associated-Rear-CVA-Kit-B44
#3977 - 3/6" x 3/8" Rubber Sealed Bearings (2 Needed) $10.98
http://www.amain.com/product_info.php/cPath/1_25_1450_42/products_id/7978/n/Team-Associated-3-16-x-3-8-Rubber-Sealed-Bearings-2
#9892 - 12mm Aluminum Rear Clamping Wheel Hex Set (2 Needed) $19.98
http://www.amain.com/product_info.php/cPath/1_25_1450_825/products_id/236851/n/Team-Associated-12mm-Aluminum-Rear-Clamping-Wheel-Hex-Set-Blue-2
I'm not sure what exactly I need for front end parts - Any parts with links or numbers are greatly appreciated. Or even what car we need the parts from.
that's tim covell's car. why didn't you ask him about the parts rundown when he posted the pics on facebook?
he's a member here, too. send him a pm.
http://www.rc10talk.com/memberlist.php?mode=viewprofile&u=417
shoman24v
Post by shoman24v »
I did ask... lol. I got the rear part down, it's just the front. I was told B4 spindles/SC10.2 front axles, but from the photo it looks like the caster block is different from what the car comes with.
Just don't want to place several orders because I missed other parts.
Front End Parts:
#9880 - Team Associated Hex Steering Block Set $4.59
http://www.amain.com/product_info.php/cPath/1_25_1450_824/products_id/209659/n/Team-Associated-Hex-Steering-Block-Set-SC10RS
#31286 - Team Associated Factory Team Aluminum Ballstud Washer (8) $5.49
http://www.amain.com/product_info.php/cPath/2_378_468/products_id/22010/n/Team-Associated-Factory-Team-Aluminum-Ballstud-Washer-8
#4449 - Team Associated 4-40 Aluminum Locknut (5) $3.69
http://www.amain.com/product_info.php/cPath/1_25_1450_369/products_id/7982/n/Team-Associated-4-40-Aluminum-Locknut-5
#7369 - Team Associated Universal 1/16" Axle Pin (4) $1.89
http://www.amain.com/product_info.php/cPath/1_25_1450_42/products_id/2438/n/Team-Associated-Universal-1-16-Axle-Pin-4
#9881 - Team Associated Hex Front Axle Set $6.39
http://www.amain.com/product_info.php/cPath/1_25_1450_1139/products_id/209660/n/Team-Associated-Hex-Front-Axle-Set-SC10RS
#9592 - Team Associated 20 Degree Caster Block (T4/B4/GT2) $3.69
http://www.amain.com/product_info.php/cPath/1_25_1450_369/products_id/2444/n/Team-Associated-20-Degree-Caster-Block-T4-B4-GT2
#3983 - Team Associated .300" Ball Stud (Black) (6) $6.39
http://www.amain.com/product_info.php/cPath/1_25_1450_369/products_id/7980/n/Team-Associated-300-Ball-Stud-Black-6
shoman24v
Post by shoman24v »
Thanks! Now this makes a bit more sense, I updated the previous posts with the correct parts.
JK Racing
Post by JK Racing »
Good, he used SC10 front/rear hex kit (available in plastic as well as the clamping alloy) & SC10 front axles.
I think I have most of these parts already in my spares :) , but I just placed an order for more wheels/tires for the stock geometery car. Maybe my next build will share wheels with my B5.
RC10th
Post by RC10th »
Hmmm, I must be the only one who had problems with B44 CVA's with stock arms and B4 rear hubs...
You'll need #7935 .187x.196 bearing and #7933 crush tubes for the rear hubs.
shoman24v
Post by shoman24v »
What kind of problems are you having?
RC10th wrote:Hmmm, I must be the only one who had problems with B44 CVA's with stock arms and B4 rear hubs....
You're not. There are more than a few guys that needed to modify the hubs to make them work properly.
One day I will buy a pair of hubs to see for myself first hand.
Users browsing this forum: No registered users and 14 guests
