LWB Optima MID with Lazer suspension.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Trinity Yokomo wheels with Schumacher tires
Carbon shocks towers, hingepin mounts, camber link mount and transmission brace.
Lazer suspension.
Steering is shaved T2 Fasttrax ballraced bellcranks with ZX ballraced link.
AE 1. gen. slipper modified to fit SPW965-01 shaft.
Ball diff. front and geared rear diff.
Steering and rear camber links are fitted with Ultima RB6 turnbuckles.
Lazer ZX belt guard fitted (not pictured)
Lazer suspension.
Gone fishing
Re: LWB Optima MID with Lazer suspension.
Wow, very nice.
I love the Optima Mid.
I should get my act together and finish mine
- DennisM
HKS_TRD -
Thanks for the kind words.
Being holiday season with lots of time off from work, I think we´re ready to see the first cople of pictures of Your MID
Gone fishing
- Mr. ED
- Has thanked: 62 times
Nice hard-core racing build Dennis.
The custom bumper gives it a nice little extra personal detail too.
SPW... Is that a different shaft from the stock mid ones? I wouldn't mind some details about how you maneged to put a decent diff on there.DennisM wrote: AE 1. gen. slipper modified to fit SPW965-01 shaft.
This is my LWB MidDennisM wrote:HKS_TRD -
http://www.rc10talk.com/viewtopic.php?f=30&t=34445
And I also started a SWB Mid
http://www.rc10talk.com/viewtopic.php?f=30&t=30497
As you can guess, I have a soft spot for the Mid
- j0pp3
- Been thanked: 4 times
Hi ED,Mr. ED wrote:Nice hard-core racing build Dennis.
OT-87 is the stock shaft. The prefix SPW use to be parts for the Kyosho Spider model but in this particular case I can't confirm.
Cheers
Joel
Joel
- Mr. ED
Thanks Joel,
I knew about SPW being for option-house and tuning parts, hence the question
I have both the spider shaft and the optima-mid one, but don't see any difference. (Actually, I have no clue which is which either.)
Enlighten us Dennis.
- DennisM
Just for You Mr. ED, I´ve taken the gearbox apart to snap a picture
The Shaft should be for Pureten GP10.
That shaft is HARD! I had to heat it to get a bite.
Gone fishing
- Mr. ED
That flattened part looks almost as if you could put the newer double-pad slipper on it
- j0pp3
That's really interesting. A slipper mod using existing parts.
Cheers
Joel
Joel
- DennisM
There´s no flat parts on the shaft - That´s why I went with the 1. gen slipper.Mr. ED wrote:That flattened part looks almost as if you could put the newer double-pad slipper on it
It´s just to drill two holes and cut a groove for the E-clips.
A while ago, I made a MID shaft using the TLR22B slipper - Took me quite a few attempts to get the flat part accurate enough by hand
Gone fishing
- Mr. ED
éJoel: sure, but drilling that hole for the crosspin is a huge barrier to me.
I guess I could get one of Alcyon's topshafts for a b4 slipper, but they're pricey.
I already tried:
- a top-shaft sold for putting a b4 slipper on the traxxas slash (2wd).
- some tower hobbies shaft for a gas car
- traxxas 4-tec top shaft
nothing worked out right: crossholes in the wrong places, too short, no groove for the E-clip at the end.
It's a good thing shelfers don't really need slippers
I already tried:
- DennisM
This morning, I did a shaft for the B4 slipper
Shaft material is a Hornet rear axle.
Time spent - app. 1 hour
Tools used:
2mm drill bit
2,5mm thread tap
Junior hacksaw
Electric drill
Bench vise
Various files
Propane torch (hardening)
20 cl oilbath (hardening)
Threadlock or snap glue
Mark the length of the flat area on the shaft.
Put the shaft in the drillchuck (the drill is mounted in the bench vise)
Then take away 0,3mm material, with a file (while the shaft spins) where the flat part is going to be (this leaves a shoulder for the inner slipper plate)
Put the shaft in the vise and file the flat part - make sure not to ruin the "shoulder" for the inner slipper plate.
Drill the 2mm hole for the pinion crosspin.
Reinstall the shaft in the chuck and cut the two e-clips grooves with the junior hacksaw while the shaft spins.
Shorten the shaft, in the correct length on the non slipper side, with the hacksaw while the shaft spins.
Now comes the hard part - put the shaft upright in the vise and drill a 2mm hole app. 7mm deep - then thread it 2,5mm.
After hardening - clean the inner threads with degreaser and let it dry.
Install a 2,5x20 screw, of good quality, with the thread lock and cut the screw head and exceed thread.
Tools used:
2mm drill bit
2,5mm thread tap
Junior hacksaw
Electric drill
Bench vise
Various files
Gone fishing
- Been thanked: 325 times
Beautiful work!
- 1280 Views
Last post by adam lancia
- 729 Views
Last post by Kyosho Fan2
- 26 Replies
- 3913 Views
Last post by CHKTM
- 39 Replies
- 5194 Views
Last post by j0pp3
- 2310 Views
Last post by ecloptima
- 25 Replies
- 2529 Views
Last post by aip47-2008
- 1461 Views
Last post by 415bayarea
- 1263 Views
Last post by egalsim
Users browsing this forum: Swath and 4 guests
