Optima MiD LWB Belt OTW-07 ?
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
Does anybody out there know where to source LWB belts for the Optima mid? I do not have BST status yet, and have even tried the original manufacturer MBL. 254XL014 are the markings on the belt. Any help would be great!!!
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: Optima MiD LWB Belt OTW-07 ?
Post by Mr. ED »
I have 2 or 3 I think; is the stinger MK2 using the same belt?
The third one is an aftermarket by another manufacturer; I will check the text on that belt for you.
I'm planning to use these belts and would rather not sell them, but hopefully I can help you find the belt standard and we find a supplier.
Can you help me also: on your LWB chassis; what is the distance from the screw holes in the rear of the chassis to the screwholes for the bumper? I want to make my own LWB chassis= without cell cut-outs but have no dimensions to start from.
Erik
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
Check you email.
This is all very interesting!
Mr. ED
Post by Mr. ED »
a01butal wrote:Check you email.
who? me?
nothing yet here ;)
a01butal
Post by a01butal »
Sorry Erik I was responding to Aaron. I have a belt and diff up in BST which he can't see yet.
highwayracer
Been thanked: 6 times
Post by highwayracer »
hey Erik,
The stinger, optima and optima mid use the same length belt. The stinger belt is made of a different material (clear yellowish brown) ands you can see the metal strands. This was probably a more fuel resistant belt.
As for the optima mid, the wheelbase was approximately half an inch shorter than the standard optima. The longer belt brought the wheelbase to 11 inches. I don't know of any other car that uses this belt.
As for the screw holes for the LWB, I'll check my lwb tonight and give you all of measurements.
Regards,
Roger
Mr. ED
Post by Mr. ED »
Hi roger, my stinger MKII had a black colour belt and the wheel base is about 20mm longer than an optima mid's; ending up somewhere over 270mm :shock:
(I know the belt takes a shorter route standard, but when I converted mine to electric it was very similar to the otpima-mid route and I was still able to maintain the long wheelbase)
I guess the longer wheelbase keeps the look of the stinger in proportion; would be pretty uggly with a swb and the huge body :lol:
aip47-2008
The markings on the belts themselves are the length, pitch, and width. The belt for the Optima conversion, and the stock Optima Mid are the same and should have 240XLF014 in white lettering. Kyosho's Optima mid custom special
stretch kit has 254XLF014 marked on them. I have a Stinger MK2 belt in my hand with 254XL016 markings, and this belt is A .5mm wider but might work. Some aftermarket belts just show the length and pitch: ex.. 240XL.
aip47-2008
The correct Kyosho part number is OTW-07, and SG-24 for the Stinger MK2!
Mr. ED
Post by Mr. ED »
well , if the teethcount is the same, and the diffs are the same (which I'm sure of) it should be a perfect match for your goal
highwayracer
Thanks for the info guys...I learn something new every day.
Regards,
highwayracer
a01butal
Post by a01butal »
Born Kyosho dumb :oops: :? :roll:
Mr. ED
Post by Mr. ED »
I guess the big question is now, can he rob the stinger of its belt or does the search continue.
Even if it continues, it should be a little easier with a second option and the somewhat lower popularity of stingers over the lwb optimas (or is that just my distorted perception?)
aip47-2008
The width is one of my concerns, the standard mid belt varies from 3mm to 3.5mm in width. While the Stinger belt is 4mm, and might be to wide to run freely. And of course the other concern is where to get more?
aip47-2008
Thanks for any and all help!!! And Erik I will post measurements for your LWB chassis later today.
Aaron
Return to “Kyosho Forum”
