More to come later!
Cheers
j0pp3
Thank you Jake, feels great having you here, Mr Engineer!Seabass wrote:Good work on this, glad to see you back here.
Jake
Exactly...what good are parts if they're not used to assemble something? They're just parts. The whole is greater than the sum of the parts!Hcp22 wrote:This will be a cool project and I like it when people use there NIP parts instead of hiding them away in some attic.
The front shock tower is the same, while the rear end only uses the lower mount. You'll also need one of the Scale Car body mount sets to mount the body (or come up with something yourself).j0pp3 wrote:Further more I'm thinking of adapting the suspension a bit to fit rally/onroad rather than buggy/offroad. Kyosho made a Ferrari F40 based on the Optima Mid and they changed the shock geometry a bit compared to the buggies. I will probably make the chassis a bit lower and use harder springs or something. There are many options as I'm about to craft the towers myself in the same material as the chassis.
Users browsing this forum: Bing [Bot] and 3 guests
